Whirlpool washer lid swich 4 wire bypass
My washer is whirlpool wtw4950xw3 lid switch has 4 wires how do I by pass to test
  • 333 Answers
SOURCE: How to bypass Lid Switch Admiral Washer
The only way to bypass this switch is fist pill the plug, gain access to the switch from under the hood. put a jumper wire on the 2 wires on the switch. that will do it. I hope this helps you out.
Posted on Nov 28, 2008
Maytag317
  • 1136 Answers
SOURCE: kenmore washer lid switch bypass failure.
HI. Check and see if you might have tripped the breaker. If there is a ground fault outlet close by. check that as well.
It sounds like you bypassed it properly. Try and reconnect the wires with the wire nut. Sometimes it doesn't connect properly.
I hope this helps you.
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
  • 37 Answers
SOURCE: Maytag Washer lid switch
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Posted on Jun 20, 2009
Maytag317
  • 1136 Answers
SOURCE: maytag washer stops at spin cycle
Hi, You can get to the lid switch by removing the screws that hold the control panel to the cabinet. This model has a fuse included with the lid switch.
Please let me knwo if I can assist you further.
Vic
Posted on Jul 01, 2009
  • 7 Answers
SOURCE: Whirlpool washer lsq9010pw -Timer not advancing
you can also check to see if the timer motor is good. not a good idea to bypass. if the presure switch was bad it would not stop filling up.
Posted on Aug 22, 2009
Whirlpool top load washer washes, rinses, drains lid lock unlocks no spin
Bypass the lid lock so it is seen as activated all the time.
Jul 10, 2017 | Whirlpool Washing Machines
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
www.shopyourway.com > Manage My Life > Questions
Jan 08, 2016 | Kenmore Washing Machines
Is there a way that incan by pass the lid light blinking
CAUTION CAUTION CAUTION CAUTION CAUTION CAUTIOON
normally this indicates lid not closed but possibly open circuit switch if washer is working cant be the switch to bypass the switch can be tecnical as you have a live feed to switch then switching wire fron switch te neon bulb then other bulb wire goes back to circuit so do away withe the switching wire from switch to bulb then live switch wire to other wire on buld that goes back to the circuit then switch has gone and the bulb no more flashing light
Aug 12, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
When lid is closed,the switch is broken and washer won't start.how do i raise top of washer to replace swich??
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jan 16, 2011 | Washing Machines
I have lid swich broken in my washer. the model no.11024692300, company is kenmore. can u please send me the discription with written & picture manual to how to fix it....thanks
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24692300&pathTaken=partSearch
Aug 25, 2010 | Kenmore 24032\24036 Top Load Washer
My Whirlpool LSR8444LQ0 will not spin. It fills up with water, washes but will not spin
Probably a broken lid switch.9530b79.jpg You can bypass the lidswitch for testing purposes to see if that is the problem. Their are 3 wires.c5cb942.gif A green ground wire and 2 live wies. Jump them to see if that washer will run. Check out this nifty video:
MANUAL AND MORE HERE
May 22, 2010 | Whirlpool LSR5132PQ Top Load Washer
Lid switch is out
I would recommend you replace the lid switch rather than by-passing it. The following link explains how:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is a safety feature that is to protect the consumer from the high speed rotation of the wash tub and the agitator. If you by-pass it, you will need to push in the timer PRIOR to opening the lid in order for the tub to stop. I would recommend by-passing as a last resort (temporary repair) while awaiting a new switch.
To by-pass a lid switch, follow the steps in the link provided to open the console. Make sure the washer is UNPLUGGED. Locate the white lid switch connector and unplug it. Remove the washer exterior case and remove the lid switch from under the washer casing. With the lid switch in your hand, cut the connector plug off, leaving about 2 inches of wire. Remove the green (center wire) from the plug and crimp the two black wires together. You have just made yourself a by-pass plug. Plug this back into the connector on the timer and the washer will now operate without the lid switch.
As I stated before, you will need to push in the timer prior to opening the lid to stop the tub. You can save the plug for future use, but use only as a temporary fix.
Replacement switches are available at searspartsdirect.com, appliancepartspros.com, repairclinic.com, and pcappliancerepair.com. They don't cost much and I provided you with easy instructions to follow.
If you have any questions, please let me know. I hope this helps you.
Jul 06, 2009 | Kenmore 24032\24036 Top Load Washer
Broken lid lock
YOU CAN WHAT YOU HAVE TO DO IS TAKE THE 2 WIRES FOR THE SWITCH AND SPLICE THEM TOGETHER BY-PASSING THE SWITCH MAKE SURE POWER IS OFF BEFOR WORKING ON ,IF ITS A PRESSURE SWITCH THAT WORKS BY THE LID BEING CLOSED TRY TAPEING OR LOCKING IT DOWN THIS MIGHT BE EASYER
Mar 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Nov 28, 2008 | Admiral AAV7000A
Wont spin or drain.
Check your lid switch. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading as item number 11 (part number 3949247). For instructions on how to replace a lid switch, click on the following link:
You can by-pass the lid switch to drain the water by performing the following:
1. Unplug the washer and remove the console and case.
2. Unplug the lid switch connector from the timer and remove the entire lid switch assembly from under the washer case.
3. With the old lid switch assembly in hand, cut the square white connector plug off the end leaving about 2 to 3 inches of wire.
4. Clip the middle wire (green, or green and yellow) flush leaving the two black wires. Strip the wire ends and twist together using a wire nut or wire crimp. You have now made yourself a by-pass plug.
5. Plug the by-pass into the lid switch receptacle on the timer and place washer case back in place.
6. Plug unit back in and move the selector know to the final spin cylce. Pull the start knob and the washer should begin to drain.
It is strongly recommended that you DO NOT run the washer for exended periods of time with the lid switch by-passed as this is a designed safety feature of the washer. And, for your own safety, do not run the washer with the exterior case removed.
This is a simple and inexpensive repair. I hope this helps you. Let me know if you require further assistance.
Aug 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
