My Epson Tylus CX4600 printer for some reason has the ink light on, and will not print. The printer sat for a few months, but at least 2 of the cartridges are nearly full.
If any ink cartridge is empty, you won't be able to print until you replace the empty cartridge. Leave any empty cartridge installed in the device until you have obtained a replacement.
The print heads will clog up in a week or two. So you also won't be able to print until you clean the print heads.
This is a utility to manage your ink. Gives an accurate count of how many ink shots are left in each cartridge. The printer told me I need a new magenta but this program says I have 13% left. It also has separate routines for cleaning the black and color (unfortunately not individual cartridges) http://www.ssclg.com/epsone.shtml
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus CX4600 All-In-One
My Epson Stylus CX4600 prints offset colors (not on top of each other) , all cartridges are new, and...
(More)
My Epson Stylus CX4600 prints offset colors (not on top of each other) , all cartridges are new, and I've performed the alignment / cleaning procedure
The printer does copy, but nothing happens when I type and press print, note book etc. Have tried...
(More)
The printer does copy, but nothing happens when I type and press print, note book etc. Have tried turning off com and printer. The inks say they are empty when they are full ! ! Had to delete printing waiting in queue > Have only had this printer about 2 weeks, they couldn't repair my other one.... this one was working fine until last night! ug!
I have a epson cx4600 printer, it was working well until it was turned off in the middle of a letter...
(More)
I have a epson cx4600 printer, it was working well until it was turned off in the middle of a letter I was printing, now all lights are flashing and the repair manual says to send the unit in for service, I believe it is a software issue with the printer, is there any repair software that can be downloaded to the printer internally?
replaced all ink cartridges and now only blue and black ever work. have tried to do maintenance but...
(More)
replaced all ink cartridges and now only blue and black ever work. have tried to do maintenance but doesn't fix.
Can't use Epson Stylus CX4600 to scan to my Mac after upgrading, told to use Image Capture... Image...
(More)
Can't use Epson Stylus CX4600 to scan to my Mac after upgrading, told to use Image Capture... Image Capture scans to Pictures folder and I created another folder... can't find the images in Pictures folder, the other new folder icon appears but nothing is in it. What do I do?
