Question about Electrical Supplies
Kipor cg2000 manual - Electrical Supplies
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Kipor generator starts ok but will not provide electricity to apppliances
first check the circuit breakers if there ok the problem is inside like over heated parts
Sep 05, 2012 | Kipor RV Generator Sinemaster IG3000
Kipor kde6700 starts but doesn't produce electricity
check your owner manuel for how to excite the gen set. check breakers and see if this one has a fuss.
Oct 13, 2009 | Kipor Parallel Wiring Kit, 30 amp Twist...
Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
Feb 19, 2009 | Kipor Electrical Supplies
Electrical Supplies Logo
73 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
