Question about Sylvania Televison & Video
On one minute then POP loud noise, burning smell
On one minute then POP loud noise, burning smell and tv down. Could this be the power board?
  • 39 Answers
Loud popping and loss of power is common on plasma TVs and is usually either the Y sustain or Z sustain boards or buffers; in these instances the damaged part will be quite evident.
If this is an LCD you might have degraded insulation on one of the pink/blue backlight power leads causing high voltage to 'arc' to the chassis.
The loud bang and smell is actually to your advantage as in these circumstances the damaged part is usually evident. It'll just be a matter of popping the back off and sleuthing around. :)
Posted on May 19, 2009
Tv picture went out
Sorry bad news these TV's work off of lights that shine thru the back of the screen if you heard a pop it was the power board that turns on those lights not an easy fix sorry.
Jan 28, 2013 | Samsung LN40D550K1FXZA - LN40D550 40 1080p...
Pop noise black screen smell
if you have a basic knowledge in electronic repair, the first thing you need to do is to remove the back cover of the tv to access the internal part. then you must check first the power supply board if their is a component that get burned. if ok, the next place to be will be the power inverter board and screen back light which the connector get burned.
Nov 02, 2012 | Philips 47PFL3603D LCD TV
Plasma made a loud pop then shut off and will not turn back on. There was also a burning smell. Any suggestions on a fix and price is appreciated.
Having similar problem and it sounds like an obvious short circuit if you heard it and can smell it, and it probably took out power supply fuse, so the first thing to do is pull off back of TV and look for obvious toasted components by eye or smell. Capacitors sometimes will pop when they go, and you can see the tops will be bulging out, or black marks, so look and smell all large capacitors first on power supply main board, then check to see if fuse blew. Sometimes the obvious is easy to fix.
Good luck,
Sep 30, 2012 | Dell W4200 42 in. HD-Ready Plasma...
Have a 65inch Mitsubishi DLP. acouple years old, just heard a loud pop,smelled like it was burning,it turns on but just sound????
hi,
Check the lamp of you tv. The lam is burned. that's why you heared a pop up sound and burning smell. Just check it and replace it. you will get the picture back.
ok
Apr 16, 2011 | Mitsubishi WD65737 65" DLP TV
The screen blanks out after approximately 20 minutes.
The power supply board is dead.Those high voltage transformers on the power supply board,one those power coil have a short in it,that why it cause this shutdown a have a loud electrical current noises.Tries websites like Shopjimmy.com.Ebay.com to buy a new refurbish power supply board for the replacement,should solved this loud electrical noises shutdown to tv.
Jul 10, 2010 | Sony BRAVIA KDL-40V3000 Television
Vizio L32 HDTV - Blew Out, No Power
Yes, I do in home warranty work on vizeo, it sounds like you need a power board and perhaps a main board. The power board is what pooped.
Nov 13, 2008 | Vizio L32 32 in. LCD HDTV
Panasonic TV Turned it self off, humming speakers, loud bang & Burning Smell
hi there, you do have a big problem at your tv, the loud bang means a part is broken, maybe you will cost 50 % of the original price of your tv. ty
Dec 26, 2007 | Televison & Video
Televison & Video Logo
804 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
