Question about Mitsubishi WD-65732 65" Projection HDTV
TV start up green light comes on but blinks and then turns off.
On the second try it stays on and fan kicks in and tv picture starts. I checked the brojector bulb and it isn't red. Model No WD-65732
  • 1 more comment
  • Anonymous Mar 17, 2014
    Mitsubishi wd-65732 no picture with red status light
  • matt martin
    matt martin Dec 17, 2016
    Flashing green light indicates power supply problem. Power supply (110 volt power cord is attached to this) I found is a very weak capacitor. Location and value is C9A39, 2200mf/35 volts at 105 degrees....replace with equal value. Also C9A45 is a 10 volt/470mf at 85 degrees. Replace C9A45 with same value, except use a 105 degree capacitor. The Flashing green light will rest. If you can....place a leaf blower in the back of the uncovered TV and dust. This is good advice as well. Thanks for asking, Matt of Martins TV Repair.
  • matt martin
    PS you will be repairing the engine on circuit.
  • Mitsubishi Master
  • 1,229 Answers
The power supply has a weak capacitor.(The power supply board has the power cord attached to this.) Location of the capacitor is C9A39. Which is 2200mf/35 volts at 105 degrees. Replace this. Also replace C9A45 ( weak as well) which is 470mf/10 volts at 85 degrees. In this case for C9A45 use same value at 105 degree cap instead. This should end flashing green light. And while you are at it. Aim a leaf blower to the back of the uncovered TV and dust, this will help keep the TV run cooler. Thanks for asking. Matt of Martins TV Repair.
Posted on Dec 17, 2016
  • 67 Answers
You have a bad ballust
Posted on May 18, 2009
Sony kds-rx60xbr1 red light blinking turn it on and off and tv goes on
The lamp for this model number is XL-5100
Before ordering the lamp, I would inspect the inside of the TV, be certain that the three fans are clean and free from dust. Often if a fan does not start the first time it may start on a restart. Due to the nature of televisions operating, dust seems drawn to these TV's. Cleaning the fans might correct your issue.
Oct 12, 2017 | Sony KDS-R60XBR1 60" Projection HDTV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
When I turn on the TV the green start up light blinks green and the TV comes on with picture and sound for about 2 seconds, then turns itself off and the code light blinks 4 times, pauses then blinks 4...
4 times blinking means Fan stopped, power is not supplied on Fan 1, Fan 2 Fan 3 and at Fan 4. Or Fan connector is not attached securely. Cleaning these fans by using a vacuum cleaner can also solve your problem. Sometimes these fans are clogged by dust.
Oct 24, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Sony- KDF-50E2000
Have you replaced its Lamp?
Symptoms shows TV needs new lamp.
Please always buy original Sony lamp for replacement.
Mar 15, 2009 | Sony KDF-E502000 50" HDTV
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Mitsubishi WD-65732 65" Projection HDTV Logo
386 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
