Question about Hamilton Beach BrewStation 47224 Coffee Maker
Clicks when turn on will not get very hot - Hamilton Beach BrewStation 47224 Coffee Maker
  • 16 Answers
I have had the same thing happen to TWO of mine.
There is a Thermal Protector Fuse at one end of the brewing element that overheats and is designed to fail(Either at 128C, 140C, or 228C). Some coffee makers have 2 different ones. The part costs about $1.70 at a local electronics supply or online. Taking apart the coffee maker is a chore, but can be done if patient. The fuse must be soldered back in place carefully. Getting it too hot will ruin the new one.
Alternatively:
If the coffee maker is less than 2 years old, you can call Hamilton Beach and they will give you instructions on how to RMA your coffee maker.You need to give them the code # on the bottom of the unit. They will request that you cut off just the plug and send it to them with a check for return shipping costs.
The latter is much easier.
Posted on May 21, 2009
My thermostat on the front dash clicks when i turn to hot
there are two hoses that usually 20 to 25 mm thick that goes from manifold to you engine fire wall , before they reach fire wall you will see a silver can shaped object with a linkage attached , replace this unit. by removing hose clamps , you should see a choke type plate inside that is jammed or broken , usually closed which what stops hot water going through you heaters .
Nov 14, 2013 | 2000 Hyundai Sonata
I have a 2001 Ford Focus DOHC. Heater doesn't blow hot. Hot cold indicator switch clicks as i9t should when I turn indicator but it doesn't seem to change anything
Feel your heater hoses and see if they are getting hot..If so when your click from the switch ,,make sure the door is switching from hot to cold
Sep 16, 2011 | 2000 Ford Focus
2004 mercury mountaineer.heat problem When turning ac knob to heat clicking sound like door opening and closing repeatedly sounds and air blows cold instead of hot.
Sep 13, 2010 | 2004 Mercury Mountaineer
Wiring program timer switch model t1905 intermatic
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} See timer manual at Intermatic: click on T1905 to see pdf manual:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial%20with%20skipper.aspx
T1905 has 4 screws: NO normally open > NC normally closed > COM > Clock
NO screw is on left
NC screw is 2nd from left
COM is 2nd from right
Clock is on right
A) How to wire t1905 for 125V
You will have four wires >> a Black and White from breaker box; and a Black and White to load
1) Black hot wire from breaker connects to COM
2) White neutral wire from breaker box connects to Clock
3) White neutral wire to load connects to Clock
4) Black wire to load connects to NO -or- NC screw [one of these screws will have no wire attached]
NO turns 'off' with times set on timer
NC screw turns 'on' with times set on timer
If you want your load to turn 'on' when timer clicks 'on' then connect Black wire to NC screw
B) How to wire t1905 for 240V
You will have four wires >> 2 hot wires from breaker box; and 2 hot wires to load. These wires might be Black and White or Black and Red
2) Red or White hot wire from breaker box connects to Clock
3) Red or White hot wire to load connects to Clock
4) Black hot wire to load connects to NO -or- NC screw [one of these screws will have no wire attached]
If you want your load to turn 'on' when timer clicks 'on' then connect black wire to NC screw
Sep 10, 2010 | Intermatic Timer T1905 24 Hour Dial 120V...
My iron will not consistently get HOT.
Hi.
The clicking sound is given by the solenoid that turns on and off the iron element. Heating cannot be turned on, and the iron keeps clicking without making any heat.
The cause of the problem can be a defective solenoid, a broken contact, or an open thermistor (it will turn the solenoid back on). The oven must be taken apart and tested to find the fault.
Regards.
Mar 02, 2010 | Rowenta Irons
2002 Ford, Explorer When turning dial from cold to hot, no hot.
it sound to me like your temperature blend door actuator is bad
Oct 29, 2009 | Ford Explorer Cars & Trucks
Starter Trouble
It sounds like you have the Starter Solinoid Wires Crossed if the Battery cables are getting hot.
Jan 22, 2009 | 2001 Mazda MPV
Ac blows hot
That sounds like the Blend Door Actulator has decided to go loopy. I heard of people turning it to hot and getting cold, Normally when this bit goes it makes a click click noise
Jan 20, 2009 | 2000 Lincoln Navigator
Hamilton Beach BrewStation 47224 Coffee Maker Logo
79 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
