Question about ViewSonic VX800 18" Flat Panel LCD Monitor
Vx800 flickers when cold
I have a Viewsonic VX800 that flickers when it is first turned on.  No picture distortion, just brightness varying randomly for the first 5 minutes or so.  It did it when it was new but only for a few seconds, now it's several minutes.  Do I need a new CCFL backlight?  thanks
  • Anonymous Oct 04, 2008
    I have this same exact problem except it has gotten to the point where it takes 15 minutes to turn on
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 64 Answers
I have repaired several Viewsonic VX800 monitors. The symptoms include a power light that flickers or flashed on and off or a screen that flashes on briefly or stays off. The problem is bad electrolytic capacitors on the power supply board. These bad capacitors do not look bad and do not swell but they do develop a high ESR (Equivalent Series Resistance). You need a ESR meter to check them. But if you have these problems, you should assume the capacitors are bad and just go ahead and replace them.
First you must open the monitor and gain access to the power supply board.
1. Remove the stand: It is held with 6 screws on the back. Also on the back are 2 black screws that must also be removed.
2. Remove the button bar from the front, bottom: It is pried off. This will expose the 2 screws holding the front plastic bezel.
3. Remove the silver plastic bezel from the front: First remove the 2 screws holding it, then you can pry the rest off. This will expose the 2 screws holding the screen to the plastic back.
4. Remove the screen and electronics from the plastic back: Remove the 2 screws holding it. The 2 speakers are glued to the plastic case. Cut the glue with a knife. The screen and electronics and speakers should lift out of the plastic back.
5. Remove the metal cover to expose the electronics: There are 2 screws holding the VGA connector and 2 screws holding the DMI connector. There are 9 screws holding the cover. These must all be removed. There is a black plastic sheet glued to the lower edge of the cover. It must be lifted. The cover should now come off.
6. Replace the bad capacitors. The power supply and signal processor are on the same board. It is marked VG800-2. The bad capacitors are surfaced mounted 100UF 25V. The bad capacitors are CM16, CM17, CM2 and CM165. The two most critical are CM16 and CM17, but they all read high ESR, so I just replace them all as long as I have them exposed.
Reassemble in reverse order.
Posted on Apr 17, 2013
3 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: viewsonic vx800
Its a problem with bad caps on the power board, problem is that it would cost you more to fix it then to buy another monitor cause your looking at the cost of either capacitors or a whole board if it can't be repaired component level and labor.
My suggestion is to get a new monitor. The repair cost would exceed the cost of a new monitor.
Posted on Feb 10, 2009
MNfisherman
  • 11896 Answers
SOURCE: when i plug in my ViewSonic VX800 monitor the
This would be a problem with the voltage transformer (power supply) or a loose wire.
Posted on Dec 13, 2009
Testimonial: "Thanks for pointing out the problem, so how do i go about fixing it?"
Its not coming on when connected
Dear Felica White,
Here are some solutions for your specific problem:
-Have you installed the right software on your PC/Mac? When no, do that first.
-Are multiple webcams attatched to your PC/Mac? Switch off all of the other webcams, but the VX800.
-Try a reboot and reconnect.
I hope I helped you with your problem!
With kind regards,
MisterN
Aug 10, 2011 | Microsoft VX800 Webcam
What are the tyre pressures have bought a vx800 with no manual or handbook and would like to ride
Solo Riding:
Front 33PSI
Rear 36 PSI
Dual Riding:
Front 33PSI
Rear 41 PSI
There is a complete scanned owners manual available here if you want to download it:
http://www.vx800.net/man_eng/02_Periodic%20maintenance.pdf
Jul 08, 2011 | 1993 Suzuki VX 800
Will not power on, the power light flashes
Hi
If the power light is flashing its mean the monitor data cable is not fix properly, or the cable is not transmit the data. change you cable and try again
Cheer
Jun 21, 2011 | ViewSonic VX800 18" Flat Panel LCD Monitor
I need a wiring diagram for a 1991 Suzuki VX800
http://vx800-restoration.blogspot.co.nz/2010_01_01_archive.html
http://2.bp.blogspot.com/_YWOnzev35gc/S0wiK39QG4I/AAAAAAAAAdU/qu55iv-f1SM/s1600-h/USA_CAN10.gif
Feb 26, 2010 | 1991 Suzuki VX 800
I turn my monitor on and I see the display breifly
hi. it sounds like the power supply has gone bad... try to purchase a new power supply cord..
thank u
rate me
Jul 19, 2009 | ViewSonic VX800 18" Flat Panel LCD Monitor
Viewsonic vx800
Feb 10, 2009 | ViewSonic VG800 18" LCD Monitor
ViewSonic VX800 18" Flat Panel LCD Monitor Logo
119 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
