Question about Samsung Washing Machines
"Quick" cycle takes 30 mins too long samsung J1045
Hi there Our samsung J1045 ( which has been a GREAT machine btw) is taking about 55 mins to complete the 30 min " quick" cycle ...we've cleaned out the pump and the machine sounds fine, it's been well maintained . Is there a 'reset' button anywhere that might help ?
    Habit-Forming:
  • 188 Answers
Is the water filling fast enough?
Posted on Dec 29, 2013
Testimonial: "I checked , the inlet tap was turned down one turn ... will do a wash tomorrow and see if that works . Will let you know"
  • 1 more comment
  • Wanda Shore
    Wanda Shore Dec 30, 2013
    Turned tap on full...no difference . We do have good water pressure .
  • Stephen Dec 30, 2013
    I just thought the water might be filling slowly (clean filters on water inlet) that was adding time to the cycle. If it looks like it is filling as fast as usual, then you can unplug it for a couple minutes as this is the only reset for the board.
  • Wanda Shore
    Yes, that does seem the most likely thing doesn\'t it ? I\'ll check the filters and make sure the hose isn\'t pinched up. We have quite \'limey\' water ..although we have filters on themain inlet, so it shouldn\'t be that.
5 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: My neptune was 30 min for a quick wash and is now 55 min
Terri, you may need to contact Maytag on this one. Here is service bulletin that was released in June of 2002... "Date: June, 2002 No: TDL0008A-S, MAH5500BWW, MAH5500BWQ Issue Software Improvements: A software improvement was introduced to the machine control board. The improvements focused on.  Reducing the number of wet clothes loads, spinning and draining complaints.  Modifications to the time estimation displayed toward the end of spin cycle. Display will no longer fluctuate erratically, time remaining.  ?dO? is no longer displayed when the door is open. Warranty See specific product for warranty information. Action This board modification was phased into production without a series change. Inventory at the National Parts Center was purged and replaced with the new control board." Hope this helps.
Posted on Aug 01, 2007
SOURCE: washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Posted on Aug 18, 2008
SearsTechToo
  • 261 Answers
SOURCE: 1 min remaining time takes 30 mins
The timer given a approximation of time left and because of balance the machine is fluffing the clothes to achieve a balance.
And for the guest it looks like you have junk in the pump. Need to access the panel below the door by removing the screws and getting a bucket, removing the large screw to the left of the pump and checking for debris in the filter, in the boot,behind the pump and look in the hole when the filter is out for damaged impeller or coins.
Posted on Sep 15, 2008
MNTECH
  • 1543 Answers
SOURCE: cycle takes forever
IE is Inlet Error. Turn off the water valves behind the washer and remove the hoses from the machine end. Look inside the spot the hoses were attached to, and use a plier to pull out the screen and clean it out. (probably only need to do the cold side) Re-instert screen(s), re-attach hoses, and turn valves back on. (Also, make sure hoses are not kinked behind machine.) Times displayed are estimates, and vary due to water fill rates, and load type and size. In your case, the water fill rate is the problem.
Posted on Jan 25, 2010
How long does the 55 degree normally run for
Depends on the water temp going into the machine. Dishwashers should be connected to cold water. Some people fit to hot water but the machine will go through the cycle too fast and you wont get a decent wash result. 55 isn't superhot for a machine (I assume this is 55 celcius?) Most machines will take about 45 mins to an hour.
Jan 03, 2015 | Dishwashers
Zanussi progress 1200
check the filter for blockages
May 01, 2014 | Washing Machines
Samsung j1045 washing machine
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Oct 14, 2012 | Samsung Front Load Washer Control Board...
The wash cycles are taking very long
Sounds like you have a heater problem. Program 5 should take around an hour and 6 should be around 30 min, both with the heater on according to asko's manual. So I would get the heater element checked.
Feb 27, 2012 | Asko W6021 Front Load Washer
Cycle takes forever
Jan 25, 2010 | LG WM1814CW Front Load Washer
Need instruction manaul for bosch wfl 2260
Programmes appear to be taking excessively long time to complete even with the quick wash button pressed - 2 hour 15 min for 30 Cotton wash cycle. Is this right or is there a fault? 30 Easy-care seems to be taking almost as long.
May 17, 2009 | Bosch Washing Machines
I have a Samsung j1045 frontloader washer and it turns on but would not move to any wash cycle or turn off.
I have a Samsung j1045 front load washer and once turned on, it wouldnt move to any washing cycle or turn off. I would have to unplug the cord from the jack to prevent any danger. Please help me and give me a solution as I have a mountain load of washing to do.
Nov 02, 2008 | Washing Machines
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Aug 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
100 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
