Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
The evaporator in the bottom refrigerator side is freezing up. What is the most common fix for this problem.
  • 58 Answers
There are two thermistors on the refrigerator side. one is the fresh food and the second one is located at the bottom left rear of the 2nd evap (refrig side) thats the shunt thermistor. ohm both out. if both are within spec then the next suspected area is the shunt valve. hope this helps... Bill
Posted on Jun 06, 2009
  • GE Master
  • 4,654 Answers
Unplug the fridge and pull away from wall. There is a panel on back that has a control board. Look on both sides for burn marks or loose welds. After you manually defrost the refrigerator with a hair dryer you need to check the defrost element and defrost thermostat. Let me know what you find, Sea Breeze
Posted on May 19, 2009
Freezer does not freeze, but stays cold like bottom unit.
How to fix freon leak an refrigerator by replacing the whole evaporator coil and charge back up to proper level R134A Side by side. Not DIY fix. video
Sep 27, 2015 | Refrigerators
Whirlpool ed25rf refrigerator side freezing on bottom
your evaporator motor may be going bad also check to see if your condensing unit and fan motor are clean this can cause similar problems.
Dec 11, 2013 | Whirlpool 25.2 cu. ft. Side-by-Side...
Water leaking from the freezer unit.
The drain hole is probably frozen over. When it goes into defrost mode every 10 hours or so, the evaporator heater removes the ice from the evaporator. There is a drain hole under the evaporator with a hose attached that goes down to a pan by the compressor fan where it is evaporated so as to not leak water on the floor. When it freezes over the drain, the water fills the bottom of the freezer until it comes out the door. A common fix to prevent the drain from freezing over is to take a bare copper 14 or 12 gauge wire and put a couple turns around the evaporator heater and stick the other end into the drain. This heats the wire enough to keep water from freezing b over the drain hole.
Dec 09, 2013 | Jenn-Air JFC2089HE French Door...
Whirlpool refrigerator bottom bin is freezing
you likely have a problem with your evaporator fan motor not blowing air throughout unit. when this fails, the cold temps fall towards bottom of both sides. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
Evaporator Coils freezing.
Hi, The most common problem is the defrost heater. It is attached to the bottom of the evaporator coil in a bracket.
If you have a meter, you can remove the element from the coil and take the two wires off. Checck the post on the element that the wirea attach to for continuity. If the element is good, it will have continuity to it. If the element is ok, check continuity on the bi-metal switch attatched to the top of the evaporator coils. It too must have continuity to be ok and it needs to be tested while still cold.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 20, 2009 | GE GSH25KGPWW / GSH25KGPBB / GSH25KGPCC...
FREEZER WONT FREEZE
Hi, Can you see if there is any frost build up in the freezer? Can you hear the evaporator fan motor running in the freezer? Most common problem is a defrost issue.
Please let me know if I can asstist you further.
Thanks
Vic
May 13, 2009 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Evaporation tube freezes
shape the hose under frig like a J-trap and it will quit sucking air up it and it wont freeze
Nov 26, 2008 | Whirlpool GD5SHAX Side by Side...
Fridge freezing
a defrost problem, is gonna cause excessive ice build up in hte frezzer lower compartment. for somereaon the hdefrost heater was not energized. most common reason is a bad defrost thermostat, clipped on one of hte evaporator coils has gone bad,
Mar 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
107 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
