Question about HP Pavilion a705w PC Desktop
We have an Hp computer. The memory reader in the
We have an Hp computer. The memory reader in the front of the computer does not work. Do you think something could of come loose or unplugged inside the computer? We have tried different cards and none of them work. We have tried the cards in another computer and they work.
Larry
  • 221 Answers
Hi Larry,
There are a few likely scenarios that would cause your card reader not to work.
1. The cable inside the computer that connects the front-panel card reader to the motherboard has come loose. You can check inside the case to make sure the cable is tight and connected. You should do this with the computer turned off, and turn it on when you're done.
2. The card reader itself has gone bad and stopped working. If this is the case, you'll need to either contact the manufacturer for repair, or you can go out and get yourself an external USB card reader for cheap.
3. The card reader is functional, but there's something wrong in the operating system that prevents the cards from being read, because the operating system doesn't know how to address the card reader. This can usually be fixed by re-installing drivers and software for the card reader.
Posted on May 18, 2009
Download pictures
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Dec 03, 2012 | HP p2-1310 Desktop PC
HP- CW450
Nov 24, 2012 | HP Cameras
My picture wont show up
Oct 29, 2012 | HP Photosmart M425 Digital Camera
Pairing envy to cell phone
Aug 30, 2012 | HEWLETT-PACKARD HP Envy 17 Notebook PC...
SD memory card reader
Many HP and Compaq computers come with memory card readers preinstalled.Figure 1: Memory card reader (yours might be different)
12_26_2011_1_43_52_am.jpgMemory cards are used primarily for importing pictures from digital cameras, but they can also be useful for sharing pictures and files. The following list shows some common types of memory cards:
  • CompactFlash I
  • CompactFlash II
  • IBM Microdrive
  • Secure Digital (SD)
  • mini-SD
  • MultiMediaCard (MMC)
  • Reduced size MultiMediaCard (RS-MMC)
  • MultiMediaCard Plus (MMC plus)
  • MultiMediaCard Mobile (MMC mobile)
  • Memory Stick
  • Memory Stick Pro
  • Memory Stick Duo
  • Memory Stick Pro Duo
  • SmartMedia
  • xD Picture Card (xD = extreme digital)
NOTE: If your computer came with a 6-in-1 card reader by KYE and was purchased before summer of 2003, update its card reading firmware by using the HP Download Web Page (in English) for your computer model name. Updating the KYE firmware allows bad blocks messages to be displayed.
A high capacity SDHC card locks up or the SDHC card cannot be readMany models of PC card readers do not work with "high capacity" formats. For example, a memory card reader capable of reading a 1 GB Secure Digital (SD) card might not read from a 16 GB SDHC card.The computer might lock up when an SDHC card is inserted into a card reader that does not support SDHC. To immediately fix the lock-up, double-click the Safely Remove Hardware icon, (in the notification area in the lower right corner of the screen), select the USB card reader, and then click Stop . The card reader will not work until the computer is restarted. You can now safely remove the memory card and use the computer for other activities.To use your higher capacity memory card without locking up the computer, do one of the following:
  • If you are using the card in a camera or other device, you can attach the device to the computer using a USB or FireWire cable. When connected, most devices appear in Windows as a Removable Disk and can be used in the same way as the card reader.
  • Use a USB memory card reading device that plugs into any open USB port. Make sure the USB device can read SDHC. These devices are inexpensive and can be used in any computer that has a USB port.Figure 2: SDCH to USB card reader adapter
An SDXC card cannot be readMake sure the card reader specifically supports the SDXC format. You can access the SDXC card by using an SDXC compatible USB reader or adapter. Look for an SDXC logo on the device or check with the device manufacturer for information.
CAUTION: Never format an SDXC memory card in a non-compatible device. Doing so will make the memory card incompatible with SDXC devices because it will erase the data on the SDXC memory card and format the card for a different file system.
Card reader stops working after using Safely Remove Hardware
CAUTION: Do not insert or remove memory cards while the light on the reader is flashing. Doing so might cause loss of data on the card or might permanently damage the card reader.
The following steps explain how to use memory cards in a card reader:
  1. Insert a memory card when the light on the reader is not flashing . You can have a memory card inserted in each slot in the card reader, at the same time.An autoplay window displays. If it does not, access the card through Windows Explorer.
  2. The memory card has a drive letter, like a DVD drive or hard drive. Use the memory card as you would use any other drive on the computer. For example, double-click the memory card icon to open a new window showing the files on the card.
  3. When you have finished working with the files on a memory card, right-click the memory card icon and select Eject . Make sure the light on the memory card reader is not on or flashing when removing the card from its slot.Figure 3: Eject feature in Windows Vista
Memory card readers are devices that use the Safely Remove Hardware icon in the notification area on the taskbar). Do not click Stop in the Safely Remove Hardware window. Doing so can disconnect the memory card reader from Windows. If this happens, restart the computer to reinitialize the memory card reader.
An alternative to restarting the computer is to use the Optimize for Quick Removal feature in Windows as follows:
  1. Open Device Manager:
    • In Windows Vista, click Start c01041253.gif , and type Device Manager into the Start Search field. Click Continueif a UAC message opens.
    • In Windows XP, right-click the My Computer , select Properties from the drop-down menu, select the Hardware tab in the System Properties window, and then select the Device Manager button.
  2. In Device Manager, click the + sign next to Disk drives to display a list of the drive devices on your computer. Memory card readers are seen as drive devices in Windows.
  3. In the list of drive devices, right-click the device that has stopped functioning to display a drop-down menu (for example, Generic USB CF Reader for CompactFlash media).Click Properties in this menu.
  4. Click the Policies tab in the Device Properties window.
  5. Select Optimize for quick removal , and then click the OK button.This setting disables write caching on the device and in Windows, so the media can be removed without using the Safely Remove Hardware feature in the taskbar. The card reader might experience a minor drop in device performance.Figure 6: Optimize for quick removal setting
Memory card icons are missing in WindowsIf you cannot access the memory card, or the drive is not listed in My Computer, use the following steps until the drive displays:
NOTE: If you are using a card reader that did not come with the computer, contact the manufacturer of the adapter for help.
  1. Remove and reinsert the memory card.If the AutoPlay window opens or if the memory card is now listed in the Computer window, you are done. Otherwise, continue with the next step.
  2. Restart the computer.If the AutoPlay window opens or if the memory card is now listed in the Computer window, you are done. Otherwise, continue with the next step.
  3. Reinstall each memory card device using Device Manager:
    a. Remove all memory cards, and unplug all USB storage devices from the USB ports.
    NOTE: Make sure you remove all USB devices.
    1. In Windows Vista, click Start , type Device Manager into the Start Search field, and press Enter .In Windows XP, click Start , right-click My Computer , select Properties , click the Hardware tab, and then click the Device Manager button.
    2. Click the plus sign next to Disk Drives to open the category.
    3. Right-click a "Generic" card reader device name and select Uninstall .Figure 7: Device Manager in Windows XP (Windows Vista is similar)
    1. Wait until Device Manager updates the list, removing the name of the Generic device.
    2. Continue uninstalling Generic card reader device names until they are all removed from the list.
    3. Restart the computer and use the card reader. If problems persist, continue to the next step.
  1. Try another memory card of the same type in the same slot. If this memory card works, the card reader is working correctly. Replace the original memory card. If the second memory card does not work, continue using these steps.
  2. If you are using Media Center, remove the memory card, maximize the Media Center window, and reinsert the memory card.
  3. Turn off the computer, disconnect the power cord, and press the power button on the front of the computer for five seconds. Reconnect the power cord and turn on the computer to test the card reader.If the AutoPlay window opens or if the memory card is now listed in the Computer window, you are done. Otherwise, continue with the next step.
  4. Some memory card readers use support USB devices. Insert a USB device into an open USB port to test whether the card reader can read from the USB device. If the device works correctly, continue to the next step. If the USB device also fails, there is a problem with USB.
    1. Turn off the computer and disconnect the power cord. Then shine a flashlight into the empty card slots in the card reader to see if any pins inside are bent. Straighten any bent pins with the end of a mechanical pencil. Replace the memory card reader or have the computer serviced if a pin is bent and is touching another pin.If the AutoPlay window opens or if the memory card is now listed in the Computer window, you are done. If there were no bent pins, continue to the next step.
    2. The memory card reader software is usually set up through a plug and play process in Windows. Some computers that came with Windows XP and built before 2003 might come with separate software for the memory card reader. If so, reinstalling the memory card reader software and then restarting the computer can fix problems with the memory card driver. To reinstall the card reader driver on HP and Compaq desktop computers, see the HP support document, Using Recovery
      10 Reset the cable connections and memory card firmware:
      1. Remove the side of the computer case by unscrewing the two retaining screws on the back of the computer and sliding the side panel towards the rear of the computer. Set the panel aside.b.Find and disconnect the cable from the back of the card reader and leave it disconnected.Figure 8: One type of connection on the reader (your computer might be different
12_26_2011_1_55_53_am.jpgMake sure that the other end of the cable is correctly connected to the motherboard or an electronic card connected to the motherboard. Make sure that the unconnected end of the cable is not touching any electronics or components inside the computer, particularly the fans.Figure 9: Connector on the motherboard (your computer might be different)
  1. Replace the computer side panel and turn on the computer.
  2. After Windows starts and the desktop displays, wait about five minutes for Windows to make the necessary hardware changes.
  3. Turn off the computer and remove the computer side panel.
  4. Reconnect the cable into the back of the card reader, replace the side panel, and turn on the computer.
  5. Check to see if the drives appear in My Computer or Windows Explorer:
    • If the memory card drives appear in Windows and work correctly you are done.
    • If the memory card drives do not appear in Windows, the drive might need to be serviced or replaced.Memory cards appear in Windows but errors occur when writing or readingIf you are having problems reading and writing data to memory cards, use the following troubleshooting tips:
      • Try a different memory card of the same type in the same slot. If this memory card works, the card reader is working correctly. Replace the original memory card.
      • Some cards have a read/write security switch on the card. Make sure the switch is set to Write Enabledbefore trying to write data to it.
      • Make sure that the amount of data you tried to store has not exceeded the capacity of the card.
      • Inspect the ends of the memory cards for dirt or material closing a hole or spoiling a metal contact. Clean the contacts with a lint-free cloth and small amounts of isopropyl alcohol. Replace the memory card if necessary.
      • Make sure the memory card is supported by the card reader.
      • Make sure the memory card is fully inserted into the slot.
      • Remove the memory card when the light is not flashing and shine a light into the empty slot to see if any small pins inside are bent. If the pins a slightly bent, turn off the computer and straighten them with the tip of a mechanical pencil. If two of the pins are touching, replace the memory card reader or have the computer serviced.
      • If errors continue, replace the memory card.
Dec 25, 2011 | Computers & Internet
Changing the card reader
HP Support > Pavilion a1730n desktop PC > Manuals,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=3339287&lang=en&
Click on the first file listed,
Upgrading and Servicing Guide (1.39M) {1.39MB}
This is a PDF file. May take a few seconds to see the first page after you click on the above file name.
Will also take additional time to fully download.
At the top of the PDF file is the Page Number box. It is to the Right of the blue Down Arrow.
Use the Down Arrow until you come to Page 7.
Pages 7 through 10 detail how to remove and replace the Memory Card Reader drive.
This page shows an illustration and photo of the motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757531&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&lang=en&product=3339287&key=null
The page automatically open with a photo of the motherboard. (Takes a split second )
Scroll down, and click on the + sign next to > Motherboard layout.
Now you can look at the illustration, and refer back to the photo.
Look at the bottom of the motherboard illustration.
You will see F_USB1 and F_USB2.
One of those USB headers is used for the Front USB ports on the Front Panel of the computer, the other one is to connect the gray cables from the Memory Card Reader. (I'm thinking F_USB2)
If you need guidance please post in a Comment.
Regards,
joecoolvette
Dec 02, 2010 | HP Pavilion a1730n PC Desktop
Memory card reader for hp pavilion doesnt work how do i find drivers or repair
If it worked before and then stopped working all of the sudden, it may be that a Windows Update caused a conflict with the driver software for the reader. Try going to the HP support website and see if more recent drivers are available. Start with hp.com and go to the support section. If it never worked and you think it might be a hardware problem, the easiest solution is to buy an inexpensive USB memory card reader. They're pretty simple to use and there are many kinds available.
Nov 07, 2010 | HP Pavilion a705w PC Desktop
I have a compaq nc6220. When I insert a memory
if ur slot is not working then i think ur adapter of memory card is write protected or if u want to use ur memory card with ur lappy so please i advice u 2 purchase card reader and then use ur M.C coz the usb slots are working efficiently with memory card........ for more help mail me at vicky.akon11@gmail.com thank u sir
Mar 24, 2010 | HP Compaq nc6220 Notebook
How do you transfer photos from memory card inserted in HP C5280 printer to my computer?
You cannot read that memory card inserted in HP printer to your Computer because that HP Card Reader port is only for direct access printing from memory card.
All you have to do is use a Multi-memory card reader into the PC where connected to USB port.
I'm sure 100 works!
Oct 09, 2009 | HP Photosmart C5280 InkJet Printer
Tower will not boot or communicate with monitor
Don't throw out that computer or replace any components just yet.
After much trial-and-error, I finally figured out the solution for this common issue with certain HP Pavillion models. It turns out to be a design flaw with the front-panel memory card reader. Somehow the card reader's firmware gets scrambled, and it prevents the computer from booting. You can test this on your machine by temporarily disconnecting the card reader cable at the motherboard header. Voila - I'll bet you $1 that your computer will now boot!
The solution is buried deep inside this HP tech support document. The card reader firmware needs to be reset.
Here\'s how to fix it once and for all:
1) With the computer power unplugged (duh), open up the case & disconnect the card reader cable at the card reader itself - NOT the end that connects to the motherboard header. Make sure the cable end is not touching any metal components before proceeding to step 2 (another duh).
2) With the cable still disconnected, fire up the computer. The tech support doc says to let it boot into Windows and stay there for about 5 minutes.
3) Shut the computer down and reconnect the cable to the card reader.
4) Turn your computer back on - your memory card reader will work and, most importantly, the computer will no longer hang at POST!
I suspect that when you fire up the computer without the cable connected, the card reader is designed to reset its firmware by grounding out through the case - sort of like a CMOS Reset jumper on a motherboard.
I hope this solution is helpful to others.
best,
JohnB
Mar 29, 2009 | HP GX612AA Pavilion Media Center M8330F...
HP Pavilion a705w PC Desktop Logo
277 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
