Question about Music
Burswood guitar manual - Music
Not reconizing input of guitar
Read your manual good and check settings. Look for master volume and pan outputs. Make sure it is connected properly to you amp. You have a left and right output, also check the amp/line switch. You can find your manual here http://line6.com/support/manuals/
Mar 03, 2013 | Line 6 Floor POD Plus Guitar Multi Effects...
Owners manual for fender dg 22 ce guitar
Go to Fender's site and see: http://intl.fender.com/en-CA/support/articles/?section=articles&search=maintenance. There are other articles that can add up to a manual, but a manual isn't usually part of an acoustic's "case candy". There just isn't much difference between one acoustic and another in form and function.
Jun 27, 2012 | Fender DG-22CE - Natural Finish 6-String...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
We have a yamaha guitar which needs repair, the serial numbers don't appear to mactch in my quest for a tech.manual. They are: QJ0093226 (EG-112 GPBL H) Can you help ?
Here is the link you need:http://europe.yamaha.com/en/products/musical-instruments/guitars-basses/el-basses/rbx/rbx374/?mode=model The manual is down loaded in pdf. Scroll down the page. The serial number has nothing to do with the manual only the model number applies.
Oct 18, 2010 | Yamaha Rbx374 4String Electric Bass Guitar
I have lost my user guide Zoom 2100 guitar
Try this link:http://www.manualnguide.com/download/manual-guide/zoom-2100-guitar-multi-effects-user-manual.html Hope this helps.
Mar 13, 2010 | Music
Manual for Epi Blues Custom 30
Having sold guitars for many years, I can tell you that Epiphone uses a standard "care and maintenance" manual for the majority of their guitars, placing them with types rather than models of their guitars. I don't sell guitars anymore, but recently purchased an Ibanez Artist, and they do the very same thing. The manual I received with this $1,200.00 guitar has on the front "Instruction Manual for Electric guitars" and is not model-specific. If you would like, I can assist you with any aspect of your guitars care and maintenance. You can receive a generalised manual directly from Epiphone for about $12.00 (but sometimes free if you've purchased recently and one was not included) or you additionally may find one on eBay or similar sites.
Thanks for using FixYa.
Jan 26, 2010 | Epiphone Music
My Tascam CD GT1 mkii guitar trainer is doing everything except when I plug my guitar into the unit, I can not hear my guitar?
Here is the manual if you don't have one:http://www.tascam.com/details;9,21,23,19.html Make sure your guitar cord is working. Make sure your are plugged into the Guitar/Mike input jack.Do not connect a guitar amp to this jack via line out on the amp or otherwise. Set the Guitar/Mike switch to Guitar. Use the Input control to adjust the level of the input.Adjust your Headphone level using the Output control.Carefully read pages 12, 13, 14 and 15 of the manual.There are various combinations of controls that would make your guitar too quiet to be heard. Example: Mix Balance page 24. Let me know if this helps.
Nov 29, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
Need manual for a black beauty guitar
Try here:http://www.gibson.com/robotguitar/robot-guitar-manual.pdf orhttp://www.gibson.com/Files/Downloads/PDFs/Gibson/USA_Owners_Manual.pdf
Oct 18, 2009 | Music
Changing strings on a pacific electric guitar
Try here:http://www.yamaha.co.jp/manual/english/result.php?div_code=guitar
Sep 09, 2009 | Music
Music Logo
21 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
