Question about Bissell 3750 Lift Off Bagless Upright Vacuum
Model 6801-3 connector plug lift off to base - Bissell 3750 Lift Off Bagless Upright Vacuum
2 Suggested Answers
SOURCE: Bissell 6595-1 with broken electrical connector
YES! If you haven't contacted Bissell yet (or bought a new vacuum) do so. They sent me a nice refurbished machine for free.
Posted on Mar 25, 2009
How do I open a Panasonic Power Nozzle to replace the belt? The Vacuum Model # is MC-V9635
The top part of the nozzle pops off just put small screw driver on side and lift up under the top lid is 2 screws then pop off by putting screw driver on sides to lift the housing off base plate
here is roller
Sears Kenmore Brush Roller 8192670 8175102 And 742454
and roller
Sears Kenmore And Power Mate Canister Power Nozzle Belt Part 20 5285
Jul 05, 2014 | Panasonic Vacuums
I just bought a bissel pro heat 2x used and i cant get the water to come out after it is on
Hello There,
There are a number of things that cold cause no water is coming out.
-Fill up the clear water bladder, lift up and push the valve underneath to release some water (it should drip)
-place the water container on the carpet cleaner and make sure it sits properly. If you lift up the container it should see some water in the deep part of the base plate (where the valve is on the bottom of the container)
-turn on the the carpet cleaner (the vacuum motor should spinning) and push the spray button(check if water shows up)
-if not, listen to the for the sound of the pump motor (unfortunately the vacuum motor is already running so the noise level is high)
-if you can't tell, you need to open the base plate 9disconnect the power first) by removing the tank and unscrew the Phillips screws all around the base plate. When you lift it up carefully you will see a small 12 Volt DC motor, this is the pump. The motor have to receive 12 V to turn on. If the motor is running (checking the sound, measuring the voltage to it) the problem is the tubes are plugged. It can be anywhere from the nozzles, the filter on the base plate, the heater (if the bottom plate is lifted up it is easy to see). The heater is made by two pieces, removing the screws it can be opened up and cleaned.
If the motor is not running (no power to it, it can be the bridge rectifier or the 3.15 A fuse (embedded in the cable harness)
Jun 15, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
I was lifting off the canister, and now there is a connector sticking up from the base. It looks like a phone jack connector. I can't reattach it. It's right in the center of the bottom of the cannister....
If the connector does not move when you gently push or pull it when you slide the canister back on the vacume it should go in place. If it is on a short piece of wire you have to gently fit it in to the hole on the other part of the vacume
Mar 11, 2011 | Bissell 3750 Lift Off Bagless Upright...
I think I need to check yhe brushes on vax swift 1500 bagless how do I get to the motor taken some screws out nothing budged and now come to a standstill . Help please
If it's like my model, remove the top cover of the base unit (surrounds the hose connector), remove the drive belt underneath, remove the upright unit from the top of the motor housing. Hopefully, now the motor is just sitting there held by the swivel mounts. Using just your hands, pull back on the motor while pushing the housing away from it on the drive shaft side. This will allow the drive shaft to come free from the housing and the motor will then lift free.
Dec 28, 2009 | VAX Appliances Vax X5 Bagless Upright...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Dec 12, 2008 | Bissell 6595 Lift Off Bagless Upright...
Just need to know how to change the belt on my vacuum cleaner
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
Dec 09, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
How do you remove the bottom plate, in order to install a new belt?
on the top of the base right behind the bumper you will see 1 screw on both sides.take those out and lift the cover off
Aug 16, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Bissell 3750-t part
WOW just spoke with bissell, and they are sending me out a refurbished 3750-r. This thing has been sitting in my basement for over 5 months, who would have known.... Thanks Guys
May 07, 2008 | Bissell 3750 Lift Off Bagless Upright...
Eureka vacuum belt how do i replace on model #4688
How To Replace Brush Roll Belt
NOTE: Turn off the switch and unplug the electrical cord
before replacing belt. Belt pulleys can become
hot during normal use. To prevent injury, avoid
touching the motor shaft when checking the belt.
1. Lower handle to floor to change belt.
2. Loosen, but do not remove, two screws to release hood.
Lift hood to remove.
3. Lift left end of brush roll.
4. Remove and discard belt.
5. Place new belt around motor shaft.
6. Place belt around brush roll pulley.
7. Align left end cap with base. Push end cap
securely into place.
8. Pull right side of brush roll to stretch belt.
Secure right end cap into base.
9. Rotate brush roll to seat belt.
10. Replace the hood. Make sure hood front is
behind furniture guard. Hood should seat
onto self-locating screw tabs.
11. Tighten screws.
You can goto this website enter in the model number 4688 and you can see detailed pictures of how to change the belt as well as print off a new user manual.
http://www.eureka.com/servlet/FindOwnersGuide
Regards
Feb 14, 2008 | Vacuums
Bissell 3750 Lift Off Bagless Upright Vacuum Logo
32 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
