Question about Fujitsu Siemens Computers & Internet
Can't turn off hibernate
Screen keeps going blank on a c2220, and looks like network off, too. Power available, shows in lcd status monitor. All conventional routes tried, such as turning off hibernate in Control Panel and through display settings, turning off any screensaver, turning of related bios settings, changing screen resolution, external/internal display switch tried. Maybe will have to take the thing apart again, but thought there might be a common software issue.
    Master:
  • Fujitsu Siemens Master
  • 247 Answers
We provide 24 hour computer support. Dial 1-800-204-4427 to contact us.Our friendly, expert tech support analysts will help troubleshoot problems with any computer or technical device with the following: Operating Systems Dell Support Number 1 800 204 4427 Video Dailymotion
Posted on Jun 22, 2017
    Sniper:
  • 84 Answers
Your system might be going into Standby. Check the settings in the Control Panel for Power.
Benimur
  • 6966 Answers
SOURCE: Data Shows up only on External Monitor, not on Laptop Screen
Since the laptop works on the external monitor, then it would be safe to assume that it is only the L:CD display part that is the issue. Often LCD display (of laptops) are working but only that you can see the actual display. One way to verify is to shine a flashlight at an oblique angle to the screen, semblance or part of the desktop could be seen. If the desktop could be seen (albeit very very dark background) then it could either be the CCF Lamps (cold cathode florescent) or the inverter that powers the lamps.
Often, the defective component would be the inverter. It is relatively easy to replace the inverted. It is sometimes more difficult and challenging cracking open the casing of the display panel of the laptop than replacing the inverter. Additionally, inverters are readily available online. It is also not surprising that inverters for other brands/models would also be used in your Toshiba.
This would be a good place to start for inverter boards. This is a nice tutorial if you are considering a DIY.
In some worst case scenario, it could be the video interface or even a loose/open flat cable from the laptop's main body towards the LCD display panel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 08, 2008
pankaj_dic
  • 1250 Answers
SOURCE: Display is wrong - only 3 resolutions available
install the display drivers, then check
Posted on Oct 28, 2008
SOURCE: Thinkpad T23 screen problem
If you take the casing apart on your monitor and pull the chip out gentley, look at the ribbon wire that goes from the monitor to your computer. It may be cracked from opening and closing. That is what was wrong with mine and it sounds like we have the same problem. I had to use another montintor until my tech group could get me a new one. Hope this helps.
Posted on Dec 08, 2008
  • 60 Answers
SOURCE: hibernating to black screen even when hibernation option is off
Try some antivirus
Posted on Jun 17, 2009
9339009664
  • 70 Answers
SOURCE: Toshiba Satellite blank screen
its a inverter circuit fault.
Posted on Aug 23, 2009
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
Monitor keeps going into sleep mode and it won't turn on so i can use it.
Monitors go to SLEEP mode when there is no computer signal coming into them. As soon as a computer signal reaches the monitor, it will automatically wake up and show the images in the screen.
Mar 27, 2010 | HP Compaq FP5315 15" LCD Monitor
My dell computer screen goes black after a while after windows xp second up grade went on. what should i do without taking upgradee off or changing screens?
Right click on your desktop go down list to properties and left click under the screensaver tab click the power tab and turn off the power saver in other words change settings to always on and no hibernation
Nov 06, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
The monitor keeps going blank after a minute or so
hey right click on your desktop.go to properties.in the propertes menu go to screen saver tab.click on the screen saver tab.in the screen saver tab menu you will see a tab called power.click on the power tab.change your settings there for the monitor.let me know if it works.
Sep 09, 2009 | Proview PL713B 17" Flat Panel LCD Monitor
Pavilion Dv1000 monitor won't show anything
Power management lets you reduce your Notebook power consumption. Your Notebook has two power management modes:
  • Hibernation is an energy-saving feature and safeguard that saves information to the hard drive, then turns off your Notebook. When you resume from Hibernation, your information returns to the screen where you were previously working. Your Notebook hibernates when the Power button is pressed, when the battery has little power left, or when your Notebook (operating on battery power) is in Sleep mode for more than one hour.
  • Sleep, also called Standby, is an energy-saving feature that reduces power to system components that are not being used. When Sleep is initiated, your information is saved in Random Access Memory (RAM), and the screen is cleared. Your Notebook is still on, but the display is blank. When you resume from Suspend, your information returns to the screen where you were previously working.
Automatically put your notebook into hibernation Windows can automatically put your computer into Hibernate mode after a specified period of inactivity. Or Windows can detect when your batteries are running low, and then automatically put your computer in Hibernate mode to save your work before the battery fails. NOTE: Using Power Options in Control Panel, you can adjust any power management option that your notebook's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control. To automatically put your computer into hibernation:
  1. In Category view, click Start , click Control Panel , click Performance and Maintenance , and then click Power Options . In Classic view, click Start , click Control Panel , and then click the Power Options icon.
  2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply . Figure 1: Enable hibernation check box c00035872.gif
  3. Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Manually put your notebook into hibernation This feature is available only on notebooks with the Windows XP operating system installed.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box. NOTE: If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start , and then click Turn Off Computer . In the Turn off computer dialog box, hold down the Shift key. The Stand By button will change to Hibernate. Click Hibernate .
Jan 06, 2009 | HP Pavilion dv1000 Notebook
Monitor displays breifly then goes to blank screen
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
Acer LCD Monitor
It is with your system. You might have hibernation enabled and many advanced video cards cannot recover from a bios or control panel timed hibernate. Start by using the Power Options from the control panel. Select "Always On" for everything and select the Hibernate tab to be sure that the Hibernate check box is not selected. Make sure you APPLY the settings. If the problem goes away, you can tweak the settings to get the power savings features you want without losing your system..
Dec 11, 2007 | Acer AL1711 17" LCD Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Computers & Internet Logo
99 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
