Question about Toshiba Portege 3500 Tablet PC
Pen not detected on especific zones of display
I have blind zones on my screen using the pen on toshiba 3500 tablet pc. mouse works ok. cannot correctly calibrate pen, only detects on left side.
Had the same problem. Just open the tablets screen enclosure. Look at the back of the LCD panel. You will see a little circuit board with several black plastic connectors. Push all these connectors firmly to the PCD. You will notice that one or more have come a bit loose. Before closing the lcd panel housing, put some adhesive tape over the connectors. This will prevent them from failing again.
Posted on Sep 06, 2010
It's a digitizer (hardware part of LCD screen) problem, U can try to buy that part and replace it or just squeeze a little bit LCD screen on the edges around (don't squeeze the screen itself but just black plastic frame around the screen) - it helped my Toshiba for a while :)
Posted on Jul 29, 2009
I have a Toshiba tablet M780-s7230 and i tried reinstalling the touch screen driver and my tablet pen and touch screen still don't work what else could i do?
Have you turned on the Touch feature on Windows 7 yet? That could be the reason why your touch screen feature is not working.
To turn it on please follow this:
1. Open your Start menu and type "Touch" into the search bar. This will show a variety of options, including the "Pen and Touch" options. Double-click it to open the "Pen and Touch" window.
2. Check the boxes next to the "Use your finger as an input device" and, if preferred, check the "Enable multi-touch gestures and inking" box as well.
3. Click "Apply" to set the options and click "OK" to exit the window.
Hope this helps!
Apr 10, 2011 | Toshiba Portege M780-S7230 Tablet PC
Something happened to where when i use the pen there is this area on the screen that will not allow the pen to touch that area of the screen or go near it, it just skips it, why?
This seems to be a common problem with this Toshiba. I squeeze the molding around the screen near the areas that the touch screen is not working. It usually happends in long blocks that don't respond to the pen.Press along the top sides and bottom running along all the edges with pressure. You may have to work with it a few times but it seems the fix mine for a while.. hope this helps
Oct 02, 2010 | Toshiba Portege 3500 Tablet PC
I have a Toshiba Portege 3500 with rotating LCD screen, my problem is that I can not rotate the wiew of the screen. The settings were changed, and now I can not rotate the view again. Thanks for your...
Do you have Windows XP with servicepack 3 installed? If so then there is a known problem with the screen driver and XP sp3. Go bakc to SP2 and reinstall de display drivers this should clear the problem.
If anyone has working tident drivers for XP SP3 I would be greatfull!!
Aug 04, 2010 | Toshiba Portege 3500 Tablet PC
Touch Screen not working or Pen?
in my opinon. you should be re instal this touch pad driver.
Mar 09, 2009 | Toshiba Portege 3500 Tablet PC
Fujitsu Stylistic 3500 Pen calibration in XP Tablet Edition
Well there is a few ways to try to fix it first with a usb mouse check that the resolution is at it's native pixel count. This can be found on the manufacture website. If it is already at that resolution ensure that the CIC XPen drivers are installed. Those should have placed a recalibration program in the control panel. If those both fail, try uninstalling the drivers and restarting, then reloading the drivers. Hope this helps! food luck and godspeed!
Jan 11, 2009 | Fujitsu Stylistic 3500 Tablet PC
Recovery CD
ok you wouldn't have been supplied a recovery cd, you have to create it, to create one have 2 blank dvd discs ready and go to start menu and select help type in a search for recovery cd, this will explain how to create one....if your computer won't load into windows you will have to re-install windows again, cheers, any other probs please get back to me.
Brett.
Dec 30, 2008 | Toshiba Portege 3500 Tablet PC
How to use the pen
Using the pen is quite simple.
You extract it from its storage space and use it as a mouse, left clicking it as you would a mouse.
By pressing the tip of the pen on an area on desktop or on an application window and maintaining the pressure for a short while, you activate the context menus (the equivalent of a right click.)
On the Windows task bar (for Windows XP) there is a small icon near the start button that shows a pen pointing outside: that is the input panel. Click the icon with a mouse or your pen, and an input area opens. In that area you write with the pen (writing Pad) or enter letters and symbols one at a time (Character Pad) or use a virtual keyboard.
Under the red X that closes the input panel there is a small gear. C;ick the gear with the pen or a mouse to configure the settings.
Your pen may have an eraser at the rear end and/OR on the side. It is used to erase characters or whole sentences.
To actually record (write) what you enter with the pen you must have a text-editing application open and running.
Whenever you approach the pen to the screen near a text-area (search area of IE or other compatible applications) a small icon appears to be clicked to enter text. This happens is you select UNDOCK in the input panel configuration.
This should get you started with the pen. Try these steps, and if you have any other questions post them as comments to this thread and it will be my pleasure to answer them.
Nov 30, 2008 | Toshiba Portege 3505 Tablet PC
The Pen
I'm not familiar with your laptop but judging from all the pdas I've had with touch screens the pen itself is only a pen, you could basicly use a wooden stick to poke at the screen and it shouldn't make a difference to the computer.
this laptop has a touchscreen If I'm not mistaken and you should be able to use it even with your fingers.
You might have a faulty touchscreen or then you need to install a driver for the screen?
Jul 04, 2008 | Averatec 3500T60 Tablet PC
Toshiba Portege 3500 Tablet PC Logo
519 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
