Question about Canon PIXMA MG5420 Inkjet Photo All-in-One
How do I clean my Cannon MG5420 - Canon PIXMA MG5420 Inkjet Photo All-in-One
Manual for cannon pixma mg5420
Canon PIXMA MG5420 Setup Guide
This is the 23 page guide, there is also a 4 pg quick start guide on
that site.
Canon PIXMA MG5420 Manual
Nov 19, 2015 | Cannon Office Equipment & Supplies
How do I fix error code 1403 mg5420?
Try removing cartridge, turning printer off/on and installing the cartridge back in. Try this couple of times and if it doesn't work, replace the cartridge.1403 indicates 'not recognised' cartridge and there is no way to reset this condition.
Feb 28, 2015 | Canon PIXMA MG5420 Inkjet Photo All-in-One
Why does my canon mg5420 say "printer not responding"
Whenever I hear of a "not responding" problem in the same sentence as "Wi-Fi" I question the wireless connection. I'm sure you've done the tests, but just to go over them; Is the printer working - can you get a test print out of it locally (setup)? Is the computer actually "talking" to the printer (Check network settings and local connections)? And, can you connect directly to the printer using a USB lead - and get a print? I would be tempted to tell the computer to find a new printer, in order to double check.
Jun 29, 2014 | Canon PIXMA MG5420 Inkjet Photo All-in-One
Mg5420
You may have accidentally installed updated firmware in your printer, so it doesn't recognize the carts anymore. You may have to "reset" the chips on your carts.
If resetting the carts doesn't help, I'd suggest contacting the place you got the refillable carts.
Jan 11, 2014 | Canon PIXMA MG5420 Inkjet Photo All-in-One
I have a Canon Pixma MG5420. I would like to print index cards using the upper cassette but I can only get the printer to print from that cassette using photo printing software. Otherwise I can't access...
Try opening control panel>devices&printers. Set the paper feed to the upper feed as permanent. Then on printer itself make sure that paper type, size and feed is where you want it.
Oct 28, 2013 | Canon PIXMA MG5420 Inkjet Photo All-in-One
I have a canon mg5420 with a paper jam code 1311 but no paper in any the locations I check?
If all else fails try this:
(at your own risk)
1. Turn on the printer
2. Open the rear cover and remove the paper feeder there
3. Insert a sheet of paper from the rear (in the slot at where the paper feeder just was.
4. turn off the printer
The printers rolls will spin as it shuts down and it will pull in the paper, hopefully clearing the paper sensor.
This worked for my MG5420
Sep 18, 2013 | Canon PIXMA MG5420 Inkjet Photo All-in-One
Canon PIXMA MG5420 Inkjet Photo All-in-One Logo
16 people viewed this question
old marine
old marine
