Question about John Deere Garden
Hard to start john deere 6330 loads of grey and white smoke
ImpalerCo
  • 13 Answers
SOURCE: hard starting smokes white like gas is getting into cylinders
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
Posted on Mar 14, 2009
wadembly
  • 513 Answers
SOURCE: i have a john deere lt160, when starting up it
to much oil or burned valve it sounds like to much oil if i can further help let me know thanks wade
Posted on Jul 04, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
  • 54 Answers
SOURCE: mower smoking and running rough
Check the gas you put in, it sounds like it had water in it.
Posted on Apr 28, 2010
nova2nv
  • 197 Answers
SOURCE: Hello my name is John. I have a 345 John Deere
345's have a habit of the choke sticking at the carb.Another problem they have is the fuel pump diaphram will crack and allow your engine to fill up with fuel,to much fuel in crankcase will end up past the rings when not running and smoke pretty bad when fired up.
Posted on Jun 25, 2010
I have a John Deere Gator 825i that that starts hard and once it does start it smokes for a few seconds then it runs clear after that. The engine does not use any significant amount of oil either.
They have a throttle body fuel injected engine. If its hard starting then smokes usually that indicates pour fuel quality or something wrong with fuel system.
Nov 07, 2017 | John Deere Garden
I have a John Deere 6330 that burns to much fuel, but has spells where it will drop rpm, and has no power.alot of black smoke during the bad spells.
Have you tried replacing the spark plug/plugs with a new set of quality US made spark plugs. NOT CHINESE IMPORT PLUGS either!
Cheesy spark plugs will fail under load if they are imports. Stick to the same heat range as the original park plugs. What brand of fuel are you using too? Stick to a quality brand of fuel and not the discount gas stations. Good luck.
Aug 15, 2015 | John Deere Garden
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
I bought a John Deere 7.0 Ft-Lbs 22"
its under warranty. let them fix it
Feb 25, 2018 | John Deere Garden
When starting John Deere 455 lawn tractor, runs great first 15-20 sec with normal black exhaust, then engine starts knocking and exhaust turns grey at that point i shut it down, tested this 3 diff times...
Unless you have a diesel, the black smoke at start up is not normal, it should be white if anything. It sounds like you are burning very rich, or no air at all, check the air filter, check the fuel cond, check the governor thing, make sure it moves freely and rebounds. Change the spark plug. I don't know what else it could be without being there. The carb could be clogged up, some carb cleaner wouldn't hurt. Hope this helps.
Jul 18, 2010 | John Deere Garden
Mower smoking and running rough
Apr 26, 2010 | John Deere 420,1020,2010,2020,2510,2520...
6330 JD every fuel line leaks with just over 100 hours.
John Deere will replace the lines with the original under warranty but as soon as your warranty runs out and you develop a leak go to solid rubber after market fuel lines and your problems will be over.The braided fuel line that is put on at the factory and replaced by Deere under warranty has a poor performance record and i would replace it,Deere can't get warranty for the repair unless the part replaced has a J.D. part number on it,but if you are willing to supply the hose,go rubber and the leaking will end.
Apr 12, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
Blue smoke hard to start no power john deere 2140
Sounds like you have a piston ring ring problem or valve guides worn. Both will cause blue smoke and hard to start. If you don't know how to do a leak down test then you'll have to give it to someone who does. The leak down test will determine if it's the rings or the valves. Also, check to make sure you don't have too much oil in crankcase
Good luck.
skidooer
Dec 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
43 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
