Question about Skagen 358SSSD Wristwatch
Can not get back on
Changed battery and can not get the back on
    Top Expert:
  • Skagen Master
  • 43,095 Answers
Ever heard of a watch PRESS .
Posted on Aug 10, 2015
How to change battery shark 88 freestyle
  • Remove back
  • Locate battery and identify type. Note battery mounting arrangement for later reference
  • Obtain replacement battery
  • Remove old battery and install new
  • Check operation
  • Install back
  • Set time, etc.
Sep 05, 2016 | Freestyle Shark 88 Watches
Battery change
  • Open back
  • Note battery polarity and remove
  • Install new battery
  • Close back
  • Set correct time
Jul 12, 2016 | Watches
How to change battery on disney accutime watch and what type of battery is needed. Thanks!
You won't know what battery it takes until you pop the back off and see what battery is in there. I've opened two identical watches and on the inside they had different movements that required two completely different size batteries. The trickiest part with Disney watches I've done is if it's musical, getting that to reset. Be careful, a lot of people don't realize how easy it is to mess up those tiny little parts, get dust in there, put the back back on wrong etc...
Feb 04, 2014 | Watches
The back wont go back on watch after changing battery
The jeweler should be able to put the back on again. He/She has the tools.
Nov 07, 2013 | Swiss Marc By Marc Jacob Leather Wrist...
Changing battery in Michael Kors watch
back off, remove old battery, install new battery, back on
Sep 21, 2012 | Michael Kors Chronograph MK5198 Watch for...
How do you change the battery on an ebel watch
Unscrew or pry off the case back. Remove the metal strap holding the battery in place. Sometimes you have to remove screw in the metal strap. Look on the battery for the type and order by that number. Put back in with fingers or plastic tweezers. Do not use metal tweezers as it will short the battery.
Dec 14, 2009 | Ebel Classic 1157111/0225 Wrist Watch
How do you get the back of the Columbia Sportswear CL7017 off to change the battery?
You can remove it with a pocket knife and it will pop out but the problem will be putting it back and that is only done with pressure that is put under a machine.If you go to a flea mkt they will do it for $5-7.00 for the battery and the cover pressure is free once the battery is changed.So make sure you get a good long time warranty battery so you dont have to change the battery frequently.
Nov 30, 2009 | Columbia Sportswear Analog Straps CL7017...
After changing the battery nothing can be changed, no function possible and"open" remains written on the display, the type of the battery is clt 1616
The battery is CTL 1616 and I had the same occurance when I opened up my model Casio model 3043. I needed to use the battery to test my model 2767 and find out if a new battery would bring it back to life (yes, it still lives). After replacing the battey back into my 3043, I jumped the (ac) to (-) and at first the watch would indicate all was well but then it would revert back to "open". I tried over and over to try and get the "open" display to clear but I was not successful. I then thought to go ahead and replace the back on the case to see if the three contact springs would change the display and sure enough, "open" no longer was in the display. The watch works perfectly as before. As for the 2767, as soon as I jumped the (ac) to (-) the "open" display went away. There is only one spring contact to the back case on the 2767 model. Unfortunately I do have an extra spring that fell out when I opened it up and I have no clue as to where it goes. I have not found anyone who can help me on the location for the shorter spring. Any advice would be most helpful.
May 20, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
How to change my battery on my fossil watch?
when you look at the back are there three small rectangular indents evenly spaced on the edge on the back? If so you'll need a special tool for opening waterproof watches. the tool adjusts to fit the three indents then press down as you turn counterclockwise. you can find the tool on amazon.com or your local jewelry store. make sure the gasket is in place and not damaged before screwing the back on.
here is a link to the tool
http://www.amazon.com/Pavilion-Professional-Waterproof-Adjustments-Caseback/dp/B000K3SK0Y
the type f battery will be written on the battery and you can usually find them at a drug store, hardware store or jewelry store that sells watches.
Dec 30, 2008 | Watches
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Skagen 358SSSD Wristwatch Logo
Top Skagen Watches Experts
Jimmy Accardi
Gary Nitowski
Are you a Skagen Watch Expert? Answer questions, earn points and help others
