Question about Omron HEM 780 Automatic Blood Pressure with Comfit Cuff
How to reset bp memory - Omron HEM 780 Automatic Blood Pressure with Comfit Cuff
How can i unlock screen on motorola droid bionic because i forgot passcode?
This might help
Droid Bionic Stuck on too many unlock attempts Verizon Wireless Community
  • Power the device off.
    • Press and hold the Power button then select Power off
    • If the device isn't responding Remove / replace the battery
  • Press and hold Volume down and Volume Up, the press Power
  • Display shows Available boot modes
    1. Normal powerup
    2. Recovery
    3. AP Fastboot
    4. BP SBF Flash
    5. BP Only
    6. AP BP USB Bypass
    7. BP Tools
  • Use volume down to scroll to "Recovery", press Volume up to select
  • Once display shows Android triage screen, press Volume up & Down at the same time
  • Display shows Android Recovery
  • Options are:
    1. Reboot System now
    2. Apply Update from SDCard
    3. Wipe data / Factory Reset
    4. Wipe Cache partition
  • Use volume down to scroll to Wipe Data/factory Reset, press power to select
  • Display shows Confirm Wipe of all user data - This can not be undone
  • Use volume down to scroll down to YES - Delete All data - Press Power to Select
  • Device will perform format wipe
  • Display then shows Android System Recovery
  • Ensure reboot system now is selected then press the Power button to select
Oct 16, 2015 | Motorola Cell Phones
How do i reset the memory on my wristech model GL52177 bp monitor?
take battery out wait for 1 minute then replace battery
Aug 13, 2014 | Health & Beauty
How to clear memory in a wristech BP wrist monitor model HL168FV
TO CLEAR MEMORY ON MODEL HL168FV:
1. PRESS UP or DOWN arrow to select a particular MEMORY ZONE, (1, 2 or 3) then press MEMORY BUTTON.
2. PRESS MODE and UP arrow AT THE SAME TIME TO ERASE ALL DATA in that zone... C L R SHOULD appear on the screen, to check it ...PRESS MEMORY AGAIN & the screen should be blank.
Mar 28, 2012 | Health & Beauty
Reset Walgreens BP cuff model wgnbpw-520
Press user select to choose 1 or 2. Press the M button to pull up memory and then press both top buttons at the same time to clear. Display reads CLA if done properly.
Jan 18, 2012 | Walgreens By HoMedics Automatic Wrist...
I have a 3MQ1-LF bp monitor. I am trying to
To erase the monitor's memory, press and hold the "M" button until the letters "CL" appear on the screen. Release and press the "M" button again. The monitor will beep twice, indicating that the memory is now empty.
Mar 15, 2010 | Life Fitness Health & Beauty
Can i reset the memory on the digital wrist bp monitor
yes, hold the memory button and the power off, it will clear out the last few numbers for you
Sep 12, 2009 | Samsung Healthy Living Deluxe Wrist Blood...
Starts to inflate then stops and get "E" message
Wrist BP monitors never give you correct BP, especially Systolic BP.
Aug 17, 2009 | Omron Healthcare Omron HEM-629 Wrist...
How do I erase memory on the HealthSmart RX
if you look around on it there should be a very small rset btton hold tat in for 5 secends OR look in the instructions.
Jun 24, 2009 | Hamilton Beach HealthSmart Rx Digital...
Readings vary widely withing 5 mins. when repeated
You should not recheck BP until at least 15 minutes after the first check because it will always get higher on reading even with a manual BP machine. As a retired nurse I have both an automatic HoMedics which I I lost the manual for and a old type arm BP cuff. My automatic is pretty close to the other cuff in readings so I know it is close. Try waiting for a while before you recheck and not talk or move around when you take it.
Mar 10, 2009 | Health & Beauty
Omron HEM 780 Automatic Blood Pressure with Comfit Cuff Logo
56 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
jay kaye
jay kaye
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
