Question about Rheem Pool & Spa
My rheum pool/spa heater won't ignite - Rheem Pool & Spa
    Top Expert:
  • Rheem Master
  • 4,292 Answers
Check gas if ok ignitor
Posted on Sep 15, 2017
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: We just moved into our home and there is no manual
Here is a link for the Manual and trouble shooting guide. Aqualink
Posted on Mar 04, 2009
  • 83 Answers
SOURCE: When Heater is turned on display shows 125, doesn't ignite/fire.
I am not sure if you have solved this issue, or not, but here is one idea. When you turn on the heater, it is reading the temp at 125/126 correct? IF this is what the heater is reading, then the problem is the Thermistor,or temp sensor, and is very easy to replace.
If you have an Owner's Manual, there are part numbers and instructions on how to replace the Thermistor. If you do not have one, follow the link below and it will take you to one online:
http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
Posted on Jul 01, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
Hayward H250 pool heater will not light
see if pressure switch full voltage both sides or hi limits
Apr 26, 2013 | Hayward Pool Products Hayward H250 250k...
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
How do you replace a pool heater pressure sensor?
check pressure switch to see if voltage both sides if not see if copper tube is plugged make sure filters are clean
Sep 22, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a new max-e-therm pool heater and after hookup everything seem fine but it won`t ignite they have leds to tell you the problem and it says ( ignition Lockout) but does not say more and I can`t find...
The users manual for these pool heaters is very thorough and address this problem in the flow chart. Try that and see if you get the solution you are looking for. A lot of the questions needed to troubleshoot cant be answered unless you are looking directly at the heater.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Jul 10, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Where to get igniter for Lite 2 Pool and Spa Heater
pool whole salers or internet you need a 4 inch mini for that heater
Jun 20, 2010 | Jandy Laars Lite2 Pool & Spa Heater -...
Pool & Spa Logo
74 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Scott Corey-reid
David Spradling
David Spradling
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
