Question about Panasonic DMR-E85H DVD Recorder
The display has R68:33 on it.
I contacted Panasonic about the "PLEASE WAIT" on display and after a few attempts to fix I was told that it would cost $130 minimum to repair.Then I found you guys and found I had the same problem that RandyChev described "PLEASE WAIT" on display. I followed his very precise and informative directions and found that I also had two bad (bulging) caps, C1270 & C1271 Thanks to the pictures he posted, I replaced them with no problems. I then was able to power it back up and all of my information was still on my hard drive, even the correct time in the display.
The only thing that I have that I don't know what it means is with the unit on the display has R68:33 on it.
I have Cox cable and they discontinued the TVGOS so I know I won't get TV Guide, is that what the R68:33 is about??
  • john May 21, 2009
    i have the same problem can u help
    Problem Solver:
  • 3 Answers
The problem ( the display has R68:33 on it) turned out to be what I had suspected, the TVGOS could not find a signal. The error code went away when the DVR had searched for the signal even though it could not find one. Cox cable discontinued the TVGOS signal so I don't get TV Guide, that is the way it is.
Again
Thanks to all that contributed to the articles on how to fix the PLEASE WAIT problem by replacing C1270 & C1271, you saved my DVR
Posted on May 24, 2009
Philips 50" Plasma with ambilight
It sounds that there is some loose contacts to some connections to your Plasma display. Almost all plasma displays will have similar configurations to display circuits, will change only with the size of the screen. If you wish to get some details http://electronicshelponline.blogspot.com/ Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jun 03, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I have a panasonic 58 inch plasma that is a little over one year old. About 2" x 8" area on the top right does not display blue color any more. What is the problem? A expensive fix?
probable bad panel. take it to aPanasonic authorized servicer. Also contact Panasonic maybe they will help you out with the cost of the repair. Since the panel is not cost effective to replace.
Jun 26, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Display does not work on phone
I do not need any help now; please remove me from your list. We called Panasonic directly no resolution. Thank you.
Jun 03, 2009 | Panasonic KX-TG5632 Phone
PLEASE WAIT
I contacted Panasonic about the "PLEASE WAIT" on display and after a few attempts to fix I was told that it would cost $130 minimum to repair.Then I found I had the same problem that hpwhite & RandyChev described "PLEASE WAIT" on display. I followed their very precise and informative directions and found that I also had two bad (bulging) caps, C1270 & C1271 Thanks to the pictures he posted, I was able to find replacement 1000uf 35v Radio Shack #272-1032 capacitors and replaced them with no problems. I then was able to power it back up and all of my information was still on my hard drive, even the correct time in the display. If you can find RandyChev's description with the pictures, it is very easy to understand
May 23, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 16, 2008 | Panasonic NN-SN657S Microwave Oven
IT say Please Wait
I had the same problem a few months ago - the fix was what gorickhoward mentioned. Two capacitors from radio shack and a $6 soldering kit made it better than new.
Steve
Jul 30, 2008 | Panasonic DMR-E85H DVD Recorder
Unlock region code panasonic dmr e85h
please wait displays in the display and the will not go away and no other function will work, i unplug the unit and when i plug it back in the please wait displays again
Apr 30, 2008 | Panasonic Televison & Video
LG RH1999H DVD Recorder
I did try removing the Hard Disk from the recorder and did a diagnostic and fix-disk using Ontrack software. Ontrack showed no structural and physical defects on the hard disk. I replaced the hard disk in the recorded and guess what! Please wait, please wait, please wait, please wait...................................
Nov 06, 2007 | Televison & Video
NO disc
The same happened to me recently, you need to go to your electronic store and purchase a CD/DVD laser lens cleaner, put it in run it problem solved
Jun 01, 2007 | Panasonic SC-DK10 System
Panasonic PV-GS32 Problems with Playback
hi well... this can be a small capacitor blown or it could be the microprocessor and it will cost like a new CAM cant know without more details good luck
Apr 28, 2006 | Panasonic PV-GS31 Mini DV Digital...
Panasonic DMR-E85H DVD Recorder Logo
155 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
