Question about Brother HL-2070N Laser Printer
Solid black line at the left side of paper after reset the drum
I have solid black line at the left side of the paper after reset the drum
  • 133 Answers
Try moving the blue panel to clean the drum after you install the toner.
plus before you do that, you need to clean up your drum by using the duster.
Posted on May 22, 2009
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
I have a solid black line running along the left side of the paper
Well I think you should clean your scanner glass thoroughly and make sure there is nothing on it...lie dirt or something even the smallest dirt can cause that ...or maybe just change your drum unit.
Dec 08, 2012 | Brother MFC9320CW All-In-One Printer
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Have black lines on left side of paper after printing
Usually this is occurs when the drum needs to be changed.
Jun 05, 2012 | Dell 3100cn Laser Printer
A Solid black line down the left side of the page
It could be 2 things...
1. Your scanner glass is dirty...open the doc feeder and clean the glass. probably Wite-Out.
2. A segment of your scanner assembly lamp is burned out. Not good, uneconomical to repair.
Jan 21, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Line across left side when scanning or faxing
check your drum for any marks, or fused toner.
James Morgan
Gigafix Ltd
Apr 15, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Black lines on paper
The problem is either with your black toner cartridge or the drum. Try changing the black cartridge first, and if this doesnt work then you will need a new drum
Dec 11, 2008 | HP LaserJet 2550L Printer
Black line on left side only
drum kit? ok you might have to repull it and look for more paper stuck somewhere blocking your toners.
Oct 16, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta Magicolor 2430DL--black line on right side of paper
Sry but you have to change drum cartridge, the line is caused form drums cleaning system, and it cant be repaired.
Oct 18, 2007 | Konica Minolta magicolor 2430 DL Laser...
Brother HL-2070N Laser Printer Logo
1,184 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
