Question about Sharp Office Equipment & Supplies
The screen of my sharp el-9900 doesn't display complete numbers. How can I fix it?
5 Suggested Answers
SOURCE: FIX numbers
If you press the setup key then 1 under FSE it will say TAB (0-9)? enter the amount of decimal places you want and it will change that for you.
Posted on Apr 20, 2008
  • 359 Answers
SOURCE: Sharp EL-2630GII Error on display
Unable to locate a manual for this specific model, but if you go to http://www.sharp.ca/manuals/, you will find one for an EL2630-P, PII, and PIII. The functions are very similar and should give you the detail that you need. Generally there will be a reset button (likely on the bottom of the machine), which often must be pushed in using a ballpoint pen or similar implement, if no other routine clear or reset procedure (such as turning off and back on) is working.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Posted on Jun 08, 2008
SOURCE: display problem
Hi, I had a similar problem and fixed it. Open the calculator and you will see that the ribbon connecting the LCD to the PCB has white and black stripes. The black stripes are the actual conductors. The white pieces are isolation between the conductors and serve the purpose of glueing the ribbon to the PCB.
Take a small flate screwdriver, its thickness has to be that of the white stripes. Heat up the end of the screwdriver with a hot air gun/lighter/hair blowdryer or whatever. Dont make it too hot. It should only be hot enough to melt the glue holding the ribbon to the PCB. Press the screwdriver on a white stripe and move the screwdriver up and down the white line which is on the PCB. Do this for each white stripe individually. Reheat the screwdirver if necessary, since there are a lot of tracks/stripes to cover.
It may be useful to use two screwdrivers: one to heat the glue of a white section and a second to cool/set the glue so that the ribbon is held in place, instead of coming loose because the glue is too hot. I did it only with one mildly hot screwdriver. It shouldn't be so hot that it actually burns you. You can test the temperature by pressing it against a hot melt glue stick (those used in a glue gun), if it melts the glue (but not too quick) it is hot enough.
It is unlikely that the ribbon came loose from the LCD, but if the previous didn't work you can try doing it on the LCD aswell.
Posted on Oct 26, 2010
walesarumi
  • 6993 Answers
SOURCE: Sharp EL-9900 wont start after
when you said it suddenly died, do you means after putting in new batteries,it did not turn on at all? If yes, below are some reasons for this problem;
Check the batter seat. I mean the position where the battery stays, look if you will find any rust of the battery terminal (metal). Rust can prevent the battery from contacting the unit, preventing it from receiving power. Get a flat screw driver, scratch the rust off, fix the battery back in and try again.
If there is no rust, then there is probably some disconnection inside the unit. This can be between the battery terminal and the board. Get a screw driver and remove all the screw. Take the unit apart and check for any lose contact between the battery terminal and the board.
I hope the above makes sense to you.......
Regards.
Posted on Apr 14, 2011
Sharp advanced EL-531x how to input number after number for stats
First you have to set the calculator in STAT mode, presumably Standard Deviation or SD. The display should show a STAT annoucer to the top. To enter values use the key M+ (or the key next to which is marked DATA. The screen displays the number of data values entered so far.
To get the statistics you must use the keys marked with x bar, n, Sigma x, etc.
Feb 27, 2013 | Sharp el-531x scientific calculator
I have a problem with my Sharp EL-531WH Scientific Calculator. It rounds off the answer. In my Chemistry class, we need exact answers. For example, an answer of 0.234 must be the answer if that's the...
Press the [SET UP] key, followed by the 0 key to bring up the display menu. You can select "FIX" followed by the number of digits to the right of the decimal point, or press cursor-down and select one of the NORM modes. Press [ON/C] to exit the menu.
Be aware that some numbers cannot be displayed exactly. For example, 1/3 is a 0.3 followed by an infinite number of 3s.
Jun 25, 2011 | Office Equipment & Supplies
Change date sharp el-2630PIII
"GT": Grand Total
"•": Neutral
" ": To set up date, time, conversion
rate, and tax/discount rate, place the
switch at the "RATE SET" position.
Date:
• Enter in the order of month, day
and year, then press to
complete the entry.
• Use to separate month, day,
and year.
• When is pressed, the number
entered is evaluated and displayed
as "date" if the value is within the
following range; "Error" is
displayed otherwise, and the
previously set date is restored.
Month: 1 - 12; day: 1 - 31; Year:
2000 - 2099 (in 4 digits) or 00 - 99
(in 2 digits)
Time:
• Enter in the order of hour, minutes,
then press to complete the
entry.
(There is no entry available for the
seconds value. The clock starts at
zero second.)
• If the hour/minute digit is less than
10, it is not necessary to enter the
first digit "0".
• Use to separate hour and
minute values.
as "time" if the value is within the
previously set time is restored.
Hour: 0 - 23 (24-hour system for
the hour entry), Minute: 0 - 59
Dec 19, 2010 | Sharp EL-2630P Calculator
How to change date and time on a sharp EL - 1197P calculator
Found Instructions for EL-1197PIII Calculator, think its the same thing
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position. Date: · Enter in the order of month, day and year, then press to complete the entry. · Use to separate month, day, and year. · When is pressed, the number entered is evaluated and displayed as “date” if the value is within the following range; “Error” is displayed otherwise, and the previously set date is restored. Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits) Time: · Enter in the order of hour, minutes, then press to complete the entry. (There is no entry available for the seconds value. The clock starts at zero second.) · If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”. · Use to separate hour and minute values. · When is pressed, the number entered is evaluated and displayed as “time” if the value is within the following range; “Error” is displayed otherwise, and the previously set time is restored. Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Apr 06, 2010 | Sharp EL-1197P Calculator
I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
date is restored.
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Apr 27, 2009 | Sharp EL-1750PIII Calculator
Need to change the time on calculator
Date:
Enter in the order of month, day and year, then press date/time button
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
When settings are complete place the switch back to GT
Mar 11, 2009 | Sharp EL-1197PIII Calculator
"Fix"
The top of the screen displays reminders on the current configuration of the calculator. The FIX will disappear if you change number display to SCIentific or ENGineering, but it will be replaced by SCI or ENG. Why does it bother you, since that part is reserved for the calculator's usage?
Hope it helps.
Jul 25, 2008 | Sharp EL-531VB Calculator
Display issues
It has recently happend to me with my sharp calculator. Experts says that it has no fix and that it would be cheaper to buy a new one.
Nov 30, 2007 | Sharp EL-531VB Calculator
Sharp EL-1801V 12 Digit 2 Color Printer
if your trouble is repeated after you switch the calculator off and on again your printer needs service in workshop.
Nov 01, 2007 | Sharp EL-2630P Calculator
71 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
