Question about Kicker Car Audio & Video
How do you install a 10 inch kicker with a built in amp
10 inch subwoofer with a built in amp
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 82 Answers
Rum a fused power line to the Battery, a fused remove on from the head unit or keyed fuse in the fuse box, ground it to the chassis, hook up the signal source using speaker wires or pre-amp cables. Bolt it down so it wont more while driving
Posted on Feb 20, 2015
trintek
  • 111 Answers
SOURCE: subwoofer wiring diagram
parallel wiring. hook all 4 positives together and run to the positive output from the amp, hook all 4 negatives together and run to the negative output from the amp.
hope this helps,
trin
Posted on Nov 19, 2007
bumpinjls
  • 13 Answers
SOURCE: 10 inch cvr kickers
Option 1 (series/parallel) = 1 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 4_2ohm_dvc_1ohm.gif
Posted on Dec 25, 2007
  • 31 Answers
SOURCE: bridge subwoofers
Without looking up the individual specs of your speaker and amp, I'll offer a few basics when it comes to bridging an amp.
Most important...find out what impedance (ohm) that your amp can handle bridged!! If you go below this rating, you will run the risk and most likely eventually overheat and short circuit the amp. You must also know the impedance of your sub (which can come in a variety) to be able to match them. Depending on this impedance match-up, it may be less beneficial to bridge the speaker to this amp. For example if there is an impedance mismatch you'll either get less power from the amp or short circuit the amp. If you know these I can help you come up with the best solution.
If you know bridging is the best option, then you'll have to know which terminals on the amp to use in order to bridge. This is how it normally works. On a 2 channel amp...you would normally take the positive from one channel to the positive on the speaker, and the negative from the OTHER channel to the negative on the speaker...and this is how you bridge the amp. The other two channels would remain UNCONNECTED. BUT!!! you have to make sure you use the correct 2 channels...it varies from manufacturer. But take heed not overload the amp...and not to overpower the sub. There are a few different ways that you can configure the subs if you find it beneficial to bridge your amp, these would take long to explain and would depend on the impedance of your subs and specs of your amp...these wiring configurations is how you match the impedance of the speakers input to the amps output (and is very important to do correctly) Look up "parallel and series" wiring configurations. Let me know if this helps, or if you need further help. Find out the impedance of your subs and the specs of your amp and i'll be able to assist you more. Hope this helps.
Posted on Mar 29, 2008
  • 26 Answers
SOURCE: how to wire my kicker solar baric
All depends on your amp. Is it 1 ohm stable or not?
Parralell:
positive (pos) on voice coil 1 (vc1) to Pos on vc2 and negative (neg) on vc1 to neg on vc2. Then speaker wire from amp to one vc only = 1ohm load.
Series:
Pos from amp to Pos on vc1. Neg of vc1 to Pos of vc2. Neg of vc2 to amp = 4 ohm load.
Posted on Jan 21, 2009
  • 12 Answers
SOURCE: i want to know the best subwoofer wiring diagram
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
Posted on Nov 30, 2009
So I just bought a kicker cx 300.1 mono block amp to run my 10 inch comp d 4 ohm 300 watt sub. I ran it parallel and it smells like the coils are burning. Help
That's only normal for the burn in period. Make sure you're not running it in 2 ohm by wiring the sub wrong. That amp is not really 2 ohm stable for a sustained period
Feb 03, 2015 | Kicker Car Audio & Video
I have 2 12 inch kicker rt dual 2 ohm subs. On a kicker cx1200.1 i want to kno how to hook it up to 2ohm to the amp. And if i can add another 10 inch kicker rt 2ohm sub in the future.
Do to the impedance Of your sub u can't run it @2ohms its going to either be @1ohm or 4ohms and your amp isn't 1ohm stable and u will risk damaging your amp. So your only option is to run it @4ohms and on a good note your sub is 100-600 watts RMS and your amp will push 400-500 watts RMS @4ohms. Now if you want to run 2 sub's in the future That amp will work perfect because it pushes 1,200watts RMS @2ohms and to wire your 2 sub's @1ohm just follow the steps in the image below. Hope this helped.25345194-v0hbouy2nvquqteoroa5j5rq-3-0.png
Dec 30, 2014 | Car Audio & Video
How do I build a shallow box for my 8 inch Kicker Comp to fit on my motorcycle
It should be built out of mdf ,That it sounds decent, As for the size of the box figgure that out your self,
Nov 27, 2012 | Kicker Comp 05C88 8" Car Subwoofer
Why does my amp turn off when i hook up my 12 inch kicker
Possibly due to a poor battery, you could try installing a power cap to prevent the amp shutting down/protect due to low voltage when the starter kicks in.
May 10, 2012 | Kicker 07CVT124 12 inch ShallowMount...
What amp should i use for 2 15-inch cvr
goto www.kicker.com you can use there recommended amp to subwoofer guide to get you answer. however i would say use the zx1500.1 amp since it has a 1500 watt rating which about the same as you subwoofers.
Jan 29, 2011 | Kicker Car Audio & Video
What kind of amp
It depends on the box you are installing them in. If you're going for sealed box they you can put 600-800 watts on them as long as you're careful with the gains and bass boost off. In a ported enclosure I wouldn't put more than 600 rms on them and still be careful with the gains. set your filter on your amp to about 80 hertz and match it on your source unit.
May 31, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
Need An amp for 2, 4ohm Kicker 12" L5
i bought two Audiobahn A2300hcx on ebay for a little over 400. look around on ebay you can really score sometime dirt cheap........ Check out audiobahn amps, never did me any wrong...........
May 06, 2010 | Kicker Solo-Baric L5 Car Subwoofer
I want to know the best subwoofer wiring diagram for three kicker cvr 10 inch subs, 2 of them are dvc 4 ohm and 1 is dvc 2 ohm, the amp that i am using is jl audio 500.1 1.5-4ohms stable. can anyone help...
Nov 29, 2009 | Kicker CVR10 Car Subwoofer
10 inch cvr kickers
Dec 17, 2007 | Kicker CVR12 Car Subwoofer
Car Audio & Video Logo
105 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
