Question about Texas Instruments TI-84 Plus Calculator
L2 disappeared the L2 under stat edit disappeared
Here's what you do in a TI-83 or TI-84:
Go to STAT > 1: Edit > UP ARROW > 2ND > INS > *List Name* > ENTER
Hope that helps!
Posted on Nov 03, 2008
Alright--heres how I fixed this on mine--what you can do is..clear all of the L-values L1-L11, 2nd >> enter >> Lists >> Del >> Yes >> Enter for each of the L-values.  Then re-enter them manually.  And there you go.
Posted on Oct 18, 2007
When i go to STAT then Edit the list that comes up are L2 and L4 and it goes up. How do i reset the functions back to L1 and L2.
Press STAT key. In the list of options that are displayed under the leftmost menu (EDIT) , press the 5:SetUpEditor. Press ENTER. It will restore the deleted list L1
Jun 12, 2011 | Texas Instruments TI-83 Plus Calculator
When I push stat abd then edit, all that comes up is a list with "name" at the bottom of the screen. How do I get off that ?
Each "list" has to have a name. Usually, the lists are named L1, L2, L3, L4, L5, L6 ect. but you can give them text names as well.
To name the list, go to Stat--> Edit --> Input a name--> Enter To input a name, either do 2nd --> L1,L2,L3 ect.. or use Alpha --> Name
Mar 01, 2011 | Texas Instruments TI-83 Plus Calculator
I want to enter data into two lists, but when I click stat, enter, I dont see a L1 column, it only starts at L2. Even if I scroll left, I can't seem to find it.
You probably deleted it as a list variable. No matter, you can restore it (without its old content).
  1. Press the [STAT] key.
  2. Under the [EDIT] menu you see a list of options.
  3. Press [5:SetUpEditor] then [ENTER]
  4. All the default lists will be restored.
Oct 31, 2010 | Texas Instruments TI-84 Plus Silver...
My ti83 has lost l2,l3, and l4 in thestat menu, therfore i am unable to check regression lines!!! panic! help
  2. Use arrow to move cursor to SetUpEditor
  3. SetUpEditor command echoes on main claculator screen.
  4. Press [ENTER]
  5. Calculator will answer Done
  6. Press [STAT] and select [1:Edit]
  7. All the 6 lists will be available for editing.
  8. Type in the values in your lists.
May 31, 2010 | Texas Instruments TI-83 Plus Calculator
How do i restore L1 and L2 in "edit" if i deleted them?
So you have deleted the L1,L2 lists. Well their contents are lost and the lists are no longer there to be filled. Right?
Have no fear, they can be restored (without your valuable data).
Press [STAT]. The Stat editor screen display 5 sub-menus.
Select [5:SetUpEditor] and press [ENTER].
Press [STAT][1:Edit] and you now see L1, and L2, and the lists you did not delete.
Enter your data again in L1 and L2.
Apr 16, 2010 | Texas Instruments TI-83 Plus Calculator
I have a trouble with my ti-83 plus. are there any body there can help me out? when i click on STAT to load my number on, but on the L1,L2, L3...and so on, it was disappear maybe somehow i delete them...
There is no L7 list. You can put your data in any available list. You can even create your own lists.
Anyway, to recover the L1,L2,L3, and L4,
Press [STAT][5:SetUpEdidor] [ENTER]
Calculator displays Done.
Press [STAT]. Under Menu EDIT, Press [1:Edit]
The List editor opens the L1,L2, etc. liststo let you enter your data.
Feb 04, 2010 | Texas Instruments TI-83 Plus Calculator
When I press stat and then 1 and I get to the lists it won't let me use L1, L2 and L3
Press [STAT][5:SetUpEditor][ENTER]
Press [STAT][1:Edit] and start entering your data, pressing [ENTER] after each data item. Press [ENTER] after the last item too.
Hope it helps.
Oct 29, 2009 | Texas Instruments TI-84 Plus Silver...
Lost L2 on the stat edit function
Go into the STAT:EDIT function and Highlight L3. Push 2nd DEL (INSERT), and Put L2 back in. If there was data in List 2, it should reappear.
Mar 08, 2008 | Texas Instruments TI-83 Plus Calculator
List dimensions
This is a pretty vague problem but not much of a problem. Your actualy plotting device of your stat plot is under your "y=". But before you do that you need to hit the stat button right next to the blue apps button. Then hit edit. These are your stat data1.gif. If you are trying to add data in you should notice what list they are under. (top of the screen L1, L2, ect.) You should also make sure that the number of data adds up for your two list. Now that you have done that you can go to "2nd" then hit "y=". If you don't want to graph your stat plots just make sure they all sat plot... off by hitting enter on the one that says that it is on. Now if you want one on hit enter and make sure your lists from your data match up with your stat plot. You can hit enter and see what one you need. they are above the 1, 2, 3, etc key. Hope this works. If all else fails you can clear your calculator by pressing "2nd", "+", "7", "1", "2". This will turn off all your stat plots if you have trouble understandsing this. But most importnat make sure your L1 and L2 match up on your stat plot with your list under your stat edit. If you don't understand this just i can help you out some more
Dec 29, 2007 | Texas Instruments TI-84 Plus Calculator
Standard deviation
Here goes if you still need this...
STAT, EDIT, put information into L1 if only one variable stats, but put info into L1 and L2 if it is frequency table stats.
Then choose Stat, over to CALC, 1, enter...if 1 variable stats then press enter again. If frequency table stats, then choose STAT, over to CALC, 1, 2nd, 1 [L!], 2nd, 2 [L2], enter.
Oct 15, 2007 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
481 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
