Question about Vacmaster VP112 commercial vacuum sealer
It wont develop vacuum. It is pumping and the lid is tight but won't pull vacuum.
Proheat sprays the water but doesn't suck it back up
Your lid is not on tight on the water collection tank it can't create a section to pull the water out. Usually take it off and putting it back on will solve the problem. good luck& God bless
Angela
Aug 23, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
My hoover steamvac wont **** up dirty water float
Check your filter screen insde the upper tank. if your model has a wrap around filter try to pull it down about 1/2" to maximize air flow.
Apr 15, 2010 | Hoover F7431-900 SteamVac Vacuum
Hoover steam vac spin scrub won't suction the water up.
I fixed my problem by repositioning the tunnel that is on the front of the pick-up tank. It had moved out of position and not allowing a tight seal. It is the white plastic piece that slides a little bit. Good luck.
Sep 20, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I turn the vacuum on and just make the noise like it's working and the brush is not moving.
check the belt on the side of beater brush take out screws in the bottom lift up plate and check the belt it either to loose or to tight or broke. You have to replace them every so offend.
Jun 28, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Not pulling water up. let out but seems to be blowing out and not pulling up water
Hello
Click HERE to get the manual. Go to figure 3.1 and clean the filter if necessary. Go to figure 3.8 and make sure pate E is clear. Make sure the part is slides up against when inserted downward is clear. Go to figure 3.11. The slotted holes in the recovery tank lid must be clear. Finally the recovery tank tank must fit snugly and air tight. I hope this works
Jun 28, 2009 | Hoover F5835900 Upright Steam Vacuum
My hoover steam vac is not releasing the cleaner
http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
Godbless
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Possible cause
Possible solution
• Solution tank not firmly in place
• Make sure tank is securely locked in
position
• Solution tank empty
• Refill tank according to instructions for
surface being cleaned
correctly
• Make sure lid is firmly in place
• Pump needs to be “primed” (when
using tool)
• See “Before using tool” section, p. 13
Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
my bissell 9200 won't release water or solution when the trigger is pulled.
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Brushes not spinning or barely spinning while operating machine
There are filters, one on the lid, the other from the bottom, has a red frame, pull it out and clean it. There maybe a foam filter on the lid covering the yellow ball, it needs to have at least a 1/4 in. gap from the top. Also make sure that the lid is on correctly and tight.
May 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Carper cleaner not working
Is the duct(#11) that sits in front of the dirty water tank in place? Is the lid of the dirty water tank on tight all around. If there is a foam filter on the inside of the dirty water tank, is there a gap between the top and the filter? Also there is no heater in the unit, so the only hot water is what you fill the tank with.
Jul 29, 2007 | Hoover F5832-910 SteamVac Supreme Vacuum
Vacmaster VP112 commercial vacuum sealer Logo
83 people viewed this question
Top Vacmaster Vacuums Experts
JoeVacs
Are you a Vacmaster Vacuum Expert? Answer questions, earn points and help others
