Question about GE Refrigerators
Frost inside and ice on floor of freezer
GE Artica PSS25NGNA side-by-side refrig. Frost under ice maker and on ice discharge chute on door. Get ice on bottom floor of freezer. Food freezes in refrigerator. Temperature settings are -2 Freezer and +34 Refrig. Changing it to normal settings doesn't hold. No water in drain pan under refrig except water in drain tube outlet (trap?). Haven't removed freezer coil panel so don't know what's going on there. These problems started about four months ago. Refrig is about 7 years old and has worked fine until now.
  • lincolnswede May 19, 2009
    Thanks for your reply. How do I get to the drain?
  • lincolnswede May 30, 2009
    Sea Breeze...I followed your recommendations and things are working well now. I would have replied sooner but I wanted to see how it was going to work out. The only problem I had was cleaning out the drain tube. I used a food baster but I could not line it up vertically. There must be a better way to flush it out. What I ended up doing was using landscape drip system tubing and pushing it down through the drain tube. The bottom of the drain tube turns up at a 45 degree angle so flushing it too strongly could end up making a big mess. Getting the back panel requires being a contortionist since it is so narrow. Thanks again!
  • GE Master
  • 4,654 Answers
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
Posted on May 19, 2009
  • 1 more comment
  • John Tripp
    John Tripp May 19, 2009
    OK, now for the easy part? Unplug the refrigerator and remove the back panel inside freezer exposing the evaporator coils. At the bottom of that coil is a drain tray that is sloped slightly in the direction where there will be a hole that takes water from the evaporator coils, every time the refrigerator defrost that is where the water begins its way to condensate tray near the compressor. (About 3 times a day) You will need to examine the tray for a crack and look into the drain and see if its blocked with ice or gunk. Anyway if you should find ice in hole then you may want to see if poring hot water down the opening if it reaches the condensate pan below the refrigerator. If you find ice in entrance I don't believe this is the reason this began because the 7 years not having this happen leads me to think something suddenly just began to happen.
    Let me know what you find and thanks for your vote, there may be more to do if you see something so please let me know because solving this helps others too Sea Breeze
    http://servicepartstec.blogspot.com/
  • John Tripp
    John Tripp May 30, 2009
    Hey Thanks! You are funny and the way you explain how the things were done or what it takes, should be put in the archives of comedy! Thanks, Sea Breeze
  • John Tripp
    Here is a link to the user manual for your refigerator. May be helpful. Sea Breeze
    http://www.geappliances.ca/images/englis...
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Oct 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
ICE MAKER FROST UP AT CHUTE
is this a u-line? Or a GE? If its a U-line make sure the freezer door is closing and sealing. If its a GE then check the gasket and make sure that is sealing.
Jul 29, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frost in freezer
The door seals on the refrigerator and freezer doors will not cause the frost at the ice chute. Frost will build up where warm moist air meets cold air. Your ice chute door seal is bad, so you need to replace the ice chut door. As far as your door gaskets go, clean the gaskets and the mating surface of the refrigerator and freezer cabinet. Use a hair dryer (NOT a heat gun) to heat the door seal up anyplace the dollar bill was loose. The magnet in the gasket will pull tight to the cabinet once the heat has softened it up. Do not open the door for 30 minutes or so to allow the seals to cool. You would only want to replace the seals if they are torn.
Jun 05, 2009 | GE Refrigerators
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker frosts over on the chute
This would indicate a problem with the ice chute door seal. Have it serviced. Air leakage would cause the frost-ice buildup.
Jun 01, 2008 | Whirlpool ED2FHSS Side by Side...
Ge profile artica side by side refrig
is it the type of doors with the plastic snap on caps that cover the hinges, if so pop them off and unscrew, if it has an ice maker on the door its more complex, good luck
Mar 13, 2008 | GE Profile PFS22 33" Artica French Door...
Frost on ice maker
look at the chute where the ice comes out the door and see if the door in there is sticking open and leaking air in some times it helps to hold a flashlight on the out side aimed up the chute while lookin down on the inside
Dec 31, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
491 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
