Question about Dell Inspiron 2650 Notebook
Does not reconize hard drive
Dell 2650 does not reconize hard drive
  • Anonymous May 21, 2009
    I have a HP Pavillion zd8000 it will not pick up the hard drive or the dvd , I bought a new hard drive and the same problem, if a use a usb hard drive or usb dvd it will pick that up, help I have tried everything, taking out the cmos battery, used 3 different install disk, if I use the usb dvd to install windows, it will install to a usb hard drive and than stop in the middle...
    thanks
  • Dell Master
  • 2,404 Answers
Turn off the laptop and then take out the hard drive from the laptop. Go ahead and reseat it back into its slot and then turn on the laptop and press F2 to go into the BIOS. It should see it in there. If it doesn't then you know the hard drive is bad and will need to be replaced.
Posted on May 18, 2009
Dell Inspiron 2650 will not boot to Windows install CD after UBUNTU Linux installed on machine.
have you went onto the BIOS to make sure that the boot options are correct e.g. CD DRIVE 1st priority?
Aug 06, 2012 | Dell Inspiron 2650 Notebook
Problem with the Dell PowerEdge 2650 Server Can't detect Hard drive
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the laptop and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
Mar 23, 2011 | Dell PowerEdge 2650 Server
How to install hyper v on dell 2650. Can Windows 2008 with hyper v be installed on a Dell 2650?
Yes, Server 2008 will install on the 2650 as long as you make sure you have enough RAM and hard drive space. Once you have Server 08 installed, you will have a to-do list to help with setting up hyper-v.
Good Luck
C2Solutions
Feb 26, 2010 | Dell PowerEdge 2650 Server
How to transfer OS and data to newer Poweredge server
The new RAID controller should read the data from the drives and work without difficulty. You will need to transfer all drives at the same time. Be sure to put the drives in the same spot in the new server.
Here are the bad news parts:
1. Your data is at risk. Make sure you do a good backup before trying this.
2. It is far more likely that your performance problems come from disk access or memory than the actual processor. If this is the case, then you probably won't be helping yourself with the migration. If you haven't already done so, analyze what is causing your performance bottleneck to make sure you are going in the right direction.
Jun 11, 2009 | Dell PowerEdge 2600 Server
I have a working Dell Poweredge 2650 with 2 x Xeon 1.8Gig processors, 5 x 36GB hard disks, running Windows 2003 Server. I have recently purchased a newer Poweredge 2650 with the same configuration except...
You should be able to do this by moving the drives all at once ALL DRIVES MUST BE PLACED IN THE SAME SLOTS 0,1,2,3,4, do not mismatch else it will be a nightmare ............HOWEVER BACKUP your data up if you are going this route,on paper it might sound like a winner,however not all that glitters is gold.controllers though they might be the same have different firmware which allow them to do different things,so if you are going to this the os drive raid 0 or 1 must be two seperate is drives.once this done,how is your raid set up for the other drives once you have a good back up to restore if there is any complication,move the over in the same order,remember POWER DOWN BEFORE YOU ATTEMPT THIS .PS REBUILDING TAKES FOREVER.
GOOD LUCK
Jun 08, 2009 | Dell Refurbished PowerEdge 2650 Server
Dell inspirion 2650 does not for mat hard drive it
you might have to Debug and then format the hard drive heres the link for debuging the harddrive and then try to format..hope this helps.
http://en.community.dell.com/forums/t/19020652.aspx?c=uk&l=en&cs=ukdhs1&s=dhs
Regards,
Khushroo
Mar 09, 2009 | Dell Inspiron 2650 Notebook
Dell Inspiron 2650 laptop is not recognizing hard drive
Do you have the dell diags cd that came with the computer.If you do ,boot to the cd and run a diag.Once in the menue do a quick test,check the device you want to check and wait for the result.You may want to test all devices since you want to make sure the computer is working and you might have only a failed hard drive.
Feb 22, 2009 | SimpleTech (STT440HD/40) 40 GB Hard Drive
RAID5 SCSI HDD
YOU WILL NEED TO UPGRADE THE FIRMWARE ON THE OLDER DRIVES
Dec 25, 2008 | Seagate (s40a102) 146 GB Hard Drive
Replace cd drive
hi there!
removing the optical drive is just easy. just follow these steps and let me know if you got it out. http://support.dell.com/support/edocs/systems/ins2600/en/sm_en/upgrades.htm#1013462
hope this helps!
Karlox
Mar 08, 2008 | Dell Inspiron 2650 Notebook
Dell Inspiron 2650 Notebook Logo
87 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
