Question about Microwave Ovens
Where do I find the error codes?
Samsung model smh918st microwave errors each time I use the presets Code is 12
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
If this is a counter top you should be able to remove the cover by removing the screws on the back, be aware that a lot of manufacturers use safety bits. about $24. once removed the tech sheet on top should have the codes and solutions
Posted on May 19, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
Samsung microwave# smh9187w-x error code 5e-how to repair?
Error code for a shorted membrane keypad switch. Manufacturer suggests unplugging the unit for an extended period of time to see if the control panel will clear the code. If not, then you probably have a defective switch.
Jul 22, 2014 | Samsung SMH7178STD Microwave Oven
Error code se micro wave samsung?
Error code indicates a shorted membrane keypad switch. Manufacturer suggests you unplug the oven for an extended period of time to see if it will clear the code itself. If not, you may actually have a bad switch.
Jul 10, 2014 | Samsung SMH7178STD Microwave Oven
Error code 13
All i kind find is it's a sensor error. turn it off or unplug for a few seconds then switch on again. if the fault is persistent it will need an engineer to look at it. is it under it's 12 month guarantee still?
Jan 13, 2013 | Samsung SMH9187ST Microwave Oven
Samsung SE error code
Followed Timm Eckenroth's suggestions in a post from 08/02/2012
and it fixed the problem on my Samsung same model as his.I was a little skeptical at first ,followed all his steps ,put it back together ,prayed about it and it worked..Thanks to Timm and the ourLord..
Nov 12, 2012 | Samsung SMH9187ST Microwave Oven
My Samsung SMH7178STD just started showing error code E-13
Hi, please click on this LINK then select 'Display Panel', then 'Microwave Is Displaying An Error Code' for instructions on what to do in the event of an error code, such as 'E-13'
Oct 31, 2010 | Samsung SMH7178STD Microwave Oven
My samsung microwave model SMH718 keeps showing an error code -SE- and keeps beeping in 4 beep intervals. How can I correct this?
I had the same problem, I changed the daylight savings time on mine and it worked untill summer, then it happend again. Finally mine quit working altogether. P.S. when this first happend samsung didn't even know what the error coded meant. It is an engineering code, meaning service engineer I believe. If it is beyond the year warranty your hosed, it would cost so much to try and fix your better off buying a new one.
Oct 25, 2010 | Samsung Microwave Ovens
Code for samsung microwave
Can you please clarify what the main problem is so we can give you exact solution? I'm sorry I didn't quite understand what you mean. Thanks!
Oct 10, 2008 | Microwave Ovens
ERROR CODE E 63 COMES ON AFTER 2 MINUTES ON SAMSUNG MICROWAVE
Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven.  If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
If the message is either ERROR or E-6, it indicates a mechanical fault.
For all error indications, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center
Oct 21, 2007 | Samsung SMH7174BC Microwave Oven
Microwave Ovens Logo
200 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
