Table does no rotate
JVC QL-A2 turntable does not run.Has been in storage for a few years in its original shipping box. Arm goes up and down but table does not turn.
  • 864 Answers
If it is belt-driven the belt may be broken or fallen off.  Lift the turntable to check underneath.  There may be a spring clip near the center of the turntable that you have to remove to lift it.
Posted on May 20, 2009
I have a jvc turntable QL-F320 and the power does not come on. Is there a fuse or something easily replaceable for this?
There will be yes! But if it is as simple as replacing it, I would doubt.
There's a service manual for the model on e-bay at the moment!
If you get stuck.
http://www.ebay.co.uk/itm/JVC-QL-F320-QL-F320B-turntable-service-manual-original-/131584946151
Mar 22, 2016 | JVC Audio Players & Recorders
What is the stylus weight adjustment and tracking weight for jvc ql-a2 quartz auto return?
Balance the stylus, then calibrate the counterweight to 0. Then turn it counter clockwise to 2. For the antiskate knob, set to 2. Use the inner numbers for an elliptical stylus, use the outer numbers if you have spherical stylus. Hope that helps, feel free to ask about anything :)
Sep 05, 2014 | JVC Vintage Ql-a2 Quartz Auto Return...
I have an older QL-45 turntable that needs tone arm adjustment- I don`t know how to set the weight so it doesn`t lower down to album so hard or heavily
I can't find the specific turntable. Who makes it?
This should work with some modifications for your specific controls...
Make a note of the tracking force setting.
Make sure the turntable is level.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Stylus Pressure/Tracking setting to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force on the Stylus Pressure/Tracking control. Play records.
Apr 11, 2011 | JVC Audio Players & Recorders
Manual for JVC QL-Y55F
You can get the manual here on link below. at the bottom. You might need to open an account for free.
http://www.vinylengine.com/library/jvc/ql-y55f.shtml
May 04, 2010 | JVC Audio Players & Recorders
Jvc ql-a5 service manual wanted, the arm it return to midlle of disk instead begining.
I had the same problem, you have to open the turntable, there's a rubber piece that pushes the arm to the arm rest. It becomes sticky with the years, and when this piece of gear goes back to the normal position, it takes the arm to the center with it. just clean the tiny piece of rubber or put a piece of paper on it.
Sep 24, 2009 | JVC Audio Players & Recorders
Looking for manual for a JVC QL-A2 turntable
www.vintageaudiomanuals.com
if you email this company on there site there let you no avilability of it but i think itll cost you mate
Aug 08, 2009 | JVC Audio Players & Recorders
JVC L T11 turntable spins to fast jerry, rigged adapter
where can I get an 11V -13V DC adaptor to power JVC turntable AL-E300?
Feb 02, 2009 | JVC Audio Players & Recorders
Technics sl-ql 15 linear tracking T/Table
Parts are discontinued for these models. You need what's called a P-Mount cartridge screw. Try the following company:
www.lpgear.com
- DAVIS
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
May 30, 2008 | Technics SL-BD22 Turntable
Sony PS-LX250H turntable won't turn
check the switch that make the lp running located it on the arm (arm uses to put it on the LP) check the motor Make sure no debris whatsoever that can disrupt the LP to turn
Aug 06, 2007 | Sony PS-LX250H Turntable
225 people viewed this question
 Grubhead
Grubhead
