Question about Broan-NuTone Allure II QS230SS Kitchen Hood
I want to replace the name plate on the allure qs2 series range hood
  • 13 Answers
SOURCE: range hood installation
you can reseal the hole with aluminium tape
you can use screws with metal flat washer that has a rubber backing
Posted on May 28, 2009
dmftrucker
  • 1922 Answers
SOURCE: Please Help. The lights on my broan allure qs2
replace the bulb sockets they get brittle and don't make good connection
Posted on Nov 04, 2009
SOURCE: 42" Allure II Broan Range Hood I put a new bulb to replace
hey guys
These are halogen bulbs, so you must be very careful not to touch them with your bare hands. Use a paper towel, or even better latex gloves. The smallest bit of oil from your skin/ hands will cause the bulb to blow as soon as they get warm
Posted on Nov 25, 2009
localwonder
  • 6784 Answers
SOURCE: noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Posted on Dec 11, 2009
SOURCE: Broan Allure QS3 push button switches for lights not working
you need a new set of controls,
Posted on Feb 24, 2010
When i removed the burnt out bulb, the whole socket, (rings) came out with the bulb, I didn't notice it until I returned with new bulb, at that time old bulb was already gone.... can i purchase a new...
I am sure that part is still available, however a model number would help in locating the part. NuTone has three different Allure series. You can check here for the part this is NuTone's website
http://www.nutone.com/index.asp
Or this company has a form to help you find the part
http://www.centralvacuumstores.com/fan_help.php
Aug 29, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
How to clean the blower wheel/housing
Yes you can.
Steps for allure 2/qs2 3/qs3
blade located to the left (squirrel cage)
1.remove filters
2.remove both screws retaining metal plate underneath filters
Now you have room to remove the blade completely for washing.
The blade is only held on by pressure (no tools needed)
When re-installing, make sure the plastic lever on the blade is securely located in any hole on the motor face.
For allure 1
Blade located dead center of the hood
Steps
1.Remove filters
2.Remove pin
3.Remove blade (only held on the pressure) you may have to pull hard
4.When re-installing: make sure the flat side of the hole in the center of the blade is alined the flat side of the shaft of the motor.
Jan 30, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Can not get halogen bulb out of my kennmore elite range hood
You will have to do the following steps.
1. remove filters
2. Unscrew 2 screws retaining metal plate under the filters.
3. Now you must remove the whole light panel. 5 screws in all, three under the front lip and two at both back ends of the same panel.
4.You now unhook the light wires (plastic connector with two wires)
Now you have the whole pnale in your hands. Unclip the socket of "problem side" and unscrew the socket from the bulb. Re-do steps 4.3.2.1
Jan 27, 2009 | Broan-NuTone Broan Range Hoods Allure II...
My broan allure turns on by itself
Isn't it suppose to turn on automatically? The broan has a heat sensor!
Jan 08, 2009 | Broan-NuTone Broan Range Hoods Allure II...
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Controller failed when a bulb blew
Control Board: Part # R111638 = $110.00
I do service calls for Broan-Nutone
Inventex Inc
Nov 12, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
90 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
