Question about Russell Hobbs Kitchen Appliances - Others
Toast is not popping up when done - Russell Hobbs Kitchen Appliances - Others
2 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: Retro Westinghouse toaster works but toast will not pop out
YES .westinghouse used a clock timer to time all of there toasters in the 40s and 50s . remove the push down knob (there is a set screw under it) and the 4 screws under the toaster . the top will come off inside next to the push down lever there is a little clock timer . a drop of oil on the moveing parts of the timer will get it ticking again .....test your work by pushing down the lever stem (with it unpluged ) it should pop up when it times out . puting back on the top can be a pain but it does go back but at some point you may wonder ! with all toasters put down a towel before working on one to keep from scraching the mirror finish ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 04, 2009
Only stays on for a few seconds and pops up
Change the light and dark setting. It needs to be darker or toast longer. It pops up right away because someone changed it to very light toast.
May 10, 2015 | Kitchen Appliances - Others
I plugged a 110v cuisinart DLC 2011 into a 220v plug creating a loud pop. Can it be fixed?
I would say that you have nothing to lose by taking it apart to see what is damaged. It might have a fuse in the unit. However the fuse might not be what you expect it to look like. In the event that the touch controls are carbon fiber, the unit is toast though.
Nov 01, 2014 | Cuisinart Blenders
My toaster will not pop up but continues to toast
The best thing you can do is call the manufacturer. It sounds as if it has a default.
Sep 18, 2014 | Toastmaster TP424 208/240 - Pop Up Toaster...
Wont pop up old toastmaster toaster
Hi mon42,
The 'click' sound indicates that the pop up mechanism is most likely intact. The problem of not popping up is most certainly caused by a worn or broken or disconnected spring which forces the toast to pop up once it's done.
You will need to take the toaster apart and look for the mechanism which pops the toaster up (look for the mechanism attached to the tray in which the toast lies). There should be a spring, or remnants of a spring, which should be fairly easily replaceable with a similar spring. This should be readily available from your local appliance spares store.
Please let me know if I can help any further or furnish you with more details. As your toaster is very old, it will be too difficult to find any documentation on the specific model.
Best wishes,
Graeme.
Jan 06, 2012 | Toastmaster Kitchen Appliances - Others
My toast willl not pop up to retrieve it sits lower than the toaster
I have the same problem with some breads. Mine is also set up for bagels, and the bread goes further into the toaster. When it pops up, it then drops back down just enough where I'm not about to stick my fingers into the darn thing......sound familiar? The only thing that I've found that helps is that, when the toast pops up, and then drops back down, I lift up on the lever that you push down to start the toast, and I can lift the toast up about an inch, and safely remove it. Try this, and see if it works for you.
Best regards, --W/D--
Apr 09, 2011 | Vacuums
The indicator light is out and the toast does not pop up on it's own.
the heating contacts are fouled up need cleaning not a big job can be done with a screwdriver and a nail file...
Oct 28, 2009 | Oster 6307 / 6309 2-Slice Toaster
Feb 21, 2009 | Kitchen Appliances - Others
I have a tefal TT550015 toast 'n' Egg and have no instructions on how to use it. Please advise
To use the egg side only, fill the measuring cup with the correct amounts of water. (One side is for boiled eggs, one is for poached eggs.) Pour the water into the basin at the bottom. For boiled- Place 1-4 eggs in the tray with the four holes. Use the sharp thing at the bottom of the measuring cup to pierce the egg shell. Place the lid over top, and hit the 'egg' button. When the light on the button goes out, remove the lid. For poached, grease the pan. Spray/ butter, whatever. DO NOT rely on the non-stick. The thick black tray for boiling eggs goes on first. With the egg in the greased pan (scrambled or whole) place the pan into the unit. There are four plastic pieces in the boiling tray to show you where it goes, the handles aligned. The round tray, with the square holes in it, can be used to warm pre-cooked meat.This is optional, and that tray goes on top. Place the lid over the top, and press 'egg'.
WARNING: this cooks by steam, and any remainder can cause burns. Be careful when removing the lid. Same goes for the product. The boiled eggs should not be touched directly.
To make an egg sandwich, load the egg side and the bread/english muffin/bagel into the toaster. Press the 'egg/toast' button BEFORE starting the toaster. The toaster will start on a timer so that the egg and toast will be done at the same time. When the toast pops up, you are good to go.
Note: there should be no water afterwards, maybe a little oil if you cooked meat. Hard water residue is easily removed with vineger and a paper towel.
Dec 02, 2008 | Back to Basics TEM-500 Egg & Muffin...
Kitchen Appliances - Others Logo
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
