Question about Sharp Aquos LC32D41U 32 in. LCD TV
Reset sharp aquos lc-c3237u
How do I reset it?
5 Suggested Answers
  • 73 Answers
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Posted on Sep 27, 2009
  • 8457 Answers
SOURCE: Sharp aquos LC-42D62U. Have audio but no picture.
Ur LCD inverter is dead,must replaced to get the picture back.
Posted on Dec 02, 2009
vinceisaac
  • 2432 Answers
SOURCE: Sharp Aquos LC-C3237U no picture backlight OK green light on
check if their is a signal on voltages around 3.3v at the inverter board if none their is a problem in the board which is in the processor.
Posted on Aug 31, 2012
SOURCE: no sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Posted on Nov 25, 2012
Aug 30, 2012 | Sharp Aquos Televison & Video
If my Sharp Aquos 37in LC-40C37U tv needs to be reset how would I do that? Not getting any power, only a green blinking light. The power supply board checked out ok.
Blinking light is an error code. Count the blinks before they repeat. Check your manual in the troubleshooting section. If you can't find it, contact a Sharp service center or try and get a service manual. Reset info is also in the user manual but you can't do it if your set doesn't power up. Are you sure about the power board?
Apr 30, 2010 | Sharp AQUOS LC-40C32U 32 in. LCD TV
Aquos 42 won't turn on
Try unpluging it for 30 seconds and plug it back in. This is how some electronics are reset.
Dec 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Dec 17, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My sound card on my sharp aquos 37 is shot. can i
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U.
Aug 23, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC32D41U 32 in. LCD TV Logo
49 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
