Question about Zeikos ZETR57A Tripod
I have a Zeikos ZE-TR57A tripod.
How do I mount my camcorder on it? My old tripod which doesn't fit this new camera had a lever to tighten the screw into the camera, but this new one doesn't.
2 Suggested Answers
SOURCE: the screws on my tripod will not tightened
Take out the whole Camera Plate. there is a plastic cap on the top of the tripoid, right by the end of your tripod extender, that comes out with a little pulling it. Now, have a look at the end of the knob housing from which your screw accidentaly came out. You will see a perfect spot in wich you need to re- insert the nut that came out. Once you do it, all you need to do is to re- insert the knob back into place, and it will "bite" the nut again at the end of the housing. Re- install the whole plate back on top of your tripod. Finally, put the plastic cap back at the top. You might need to gently tap it in. Done deal . Problem resolved ! Enjoy your tripod !
Posted on Dec 12, 2012
How to purchase quick release replacement for Zeikos ZE-TR101A tripod?
a) find a vendor
b) visit vendor
c) hand over money
d) walk away with quick release.
Or try Ebay or the manufacturer
Sep 27, 2016 | Zeikos Photography
What do I do to attach the camera after attaching it to the mount piece?
the quick release plate, that you are calling the "mount piece" will just snap onto the head of the tripod - if you aren't sure, a good way is to take off the QR plate from the camera, and then, with the screw threads face up, see how it fits into the head - many times, you have to engage the spring lever, so when you set the plate inside the head, it will snap locked into place. Then, re-mount it on your camera, and do the same thing, and there ya go.
Jul 01, 2014 | Manfrotto Camera Supports 3405BN JR. BLK...
The screws on my tripod will not tightened
Jan 21, 2012 | Zeikos ZETR57A Tripod
USERS MANUAL FOR ZEIKOS ZE-SB700 FLASH FOR NIKON CAMERA
what setting do i put my nikon d7000 on to use the zeikos ze-sb700 flash?
Nov 13, 2011 | Nikon SB700 Flash
I need to purchase screw that attaches scope to window mount on a 78-4405
The mount has a 1/4-20 screw that fits most camera equipment. If you have the scope (spotting scope) it should have that hole in the bottom of the mounting ring. If the screw is missing from the window mount then most 1/4-20 tripod screws will work or you may substitute a cap screw and flat washer, to work with an Allen wrench for tightening.
Feb 07, 2011 | Bushnell 784405 Tripod
Having trouble mounting my Nikon D3000 to Zeikos 72" tripod. There is not manual included and I'm not sure how to get it to stay on the quick release plate, other than manually rotating the camera...
Quick release plates on all tripods are in two pieces. One stays on the tripod and provides a locking mechanism to secure the camera and the other stays connected to the tripod socket on the camera.
Jan 08, 2011 | Cameras
I have a SLIK Single Action Panhead Tripod. How do I mount the camera on the tripod?
it is a quick release plate. there is usually a button or lever to release the plate. you then screw the plate into the bottom of your camera or camcorder and mount the plate back onto the tripod. you can leave the plate on your camera when you store it to allow for faster setup.
Jun 03, 2010 | Slik AF-1100E Trigger Release Ball Head...
Screwing camera onto tripod quick release
Usually the camcorder has a hole next to the mounting screwhole. The plastic nub fit into the unthreaded hole, the mounting screw screws into the threaded hole. The nub is to help prevent the camcorder from rotating while you are using it on the tripod.
Feb 08, 2009 | Sakar TR-60 Tripod
I need the camera mount to use with my Ambico V-0540 tripod
T-mount is the correct term.  Ebay, if you go that direction has some.  The other alternative is B & H Photo Video.
Nov 03, 2008 | AmbiCom V0552 Tripod
Bogen Manfrotto 3047 head
Dear spiderinkart,
To get the camera to secure properly to the release plate make sure that the bolt is screwed entirely into the camera bottom and then there should be a larger knob that rotates around the bolt that tightens down to the camera body. What I do to get a really tight fit is point the arrow on the bottom of the release plate labeled lens (that arrow when properly mounted should be pointed towards the front of the lens) to a 45 degree angle to the left of the lens, then I snug down the knob, and then I grab the release plate and turn it until the lens arrow is aligned with the front of the lens. As far as quick releaseing the camera from the legs when secured on the release plate you should be able to pull the lever away from the head and it should simply release the camera with the plate attached.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Mar 16, 2008 | Bogen Communication Bogen Manfrotto 3047...
Zeikos ZETR57A Tripod Logo
44 people viewed this question
Top Zeikos Photography Experts
ray gallant
Tony Parsons
Tony Parsons
Are you a Zeikos Photography Expert? Answer questions, earn points and help others
