Question about Acer Aspire T650 (AST650UC3601) PC Desktop
Rear brake shoe adjustment 2005 kia rio
I have a 2005 kia rio, i need to find out how to adjust the rear brakes after replacing. there seems to be no manual adjustments
  • Dick
    Dick May 11, 2010
    Acer Aspire desktop computers do not have rear brakes.
    Sergeant:
  • 199 Answers
Yeah there is a manual adjustment here is how to do it
take wheel out
take drum out
there is a spring in the middle which you can regulate to expand the brake shoes
Posted on May 26, 2009
I am working on a 2005 Kia Rio with drum brakes. I have put new brake shoes on it and now the drum will not go back on over the brake shoes. What do I need to do to get it back on the car?
Make sure the adjuster is set all the way in, that the shoes are centered on the backing plate and that there is no ebrake cable tension.
Jun 13, 2015 | 2005 Kia Rio
Adjusting Kia rio handbrake cable
The brake drum does not fit due to the pressure in brake cylinders. Some of the cylinders are designed to keep a little pressure on, even when the pedal is released. The reason is that you will have instant reaction on pushing break pedal because there is no free space between drum and pads. You need to take clamp and push the pistons back in cylinder, but only that much so you can fit the drum. After the drum is tightened you must pump the brake pedal until you can fell that there is no free fall. The hand brake should be ok, but check it just to be shore. If there is need to tension the cable, it can be done under lever from outside the car (you must go under the car).
Apr 28, 2014 | 2002 Kia Rio
Adjusting the parking brake on a 2005 saturn reley
The first step ALWAYS to adjust the REAR BRAKE SHOES. The parking brake should not go "out of adjustment" UNLESS the rear brake shoes are:
1. Worn
2. Have recently been replaced and not set correctly
3. Are out of adjustment due to wear.
Turning the adjustment nut (unlike what Autozone seems to imply) is the LAST thing you should do AFTER all other possibilities have been eliminated.
Adjusting the rear brakes can often be accomplished easily in an empty parking lot. Simply accelerate in REVERSE to about 5~10 MPH and stomp on the brake pedal. Repeat this 3~5 times. You will often discover afterward that your forward braking performance has suddenly improved and that Parking brake is now miraculously "back in adjustment."
Feb 08, 2014 | 2005 Saturn Relay
Rear brakes
Removal
1.Remove rear wheel and tire assembly from vehicle.
2.Remove rear brake drums from hub and bearing assemblies after loosening the two brake drum screws.
3.Be sure that the parking brake pedal is in the release(most upward) position.
4.Completely loosen square nut of the rear parking brake cable. Then create slack in the rear parking brake cables.
5.Remove adjuster spring from adjust lever and brake shoe.
6.Remove adjust lever and turn the adjusting wheel of adjuster assembly to the direction of the arrow as shown.
7.Remove the strut spring and the lower retracting spring from the brake shoe.
8.Remove the upper return spring from the brake shoe.
9.Remove brake back plate hold down spring and pin from the leading brake shoe assembly.
10.Remove the leading brake shoe. Then remove the adjuster assembly, strut and anchor spring from the trailing brake shoe.
11.Remove the trailing brake shoe from the brake back plate after removing hold down spring and pin.
12.Remove the trailing brake shoe from the rear parking cable.
13.Remove parking pivot lever from the leading brake shoe.
Replacement
1.Lubricate the eight shoe contact areas on the back plate and anchor.
2.Install the trailing brake shoe to the rear parking cable.
3.Install trailing brake shoe on brake back plate and install the trailing brake shoe hold down spring and pin on the brake shoe.
4.Tighten the square nut of rear parking cable.
5.Install the anchor spring then install adjuster assembly, and strut.
6.Install leading brake shoe on brake back plate.
7.Install the brake shoe upper return spring, strut spring and the lower retracting spring to the brake shoe.
8.Properly rotate the adjusting wheel of adjuster assembly to the direction of the arrow in as shown.
9.Install the adjuster spring on the adjust lever and leading brake shoe assembly.
10.Install the leading brake shoe hold down spring and pin on the brake shoe.
11.Adjust brake shoes assemblies so as not to interfere with brake drum installation.
12.Install the rear brake drums on the hubs.
13.Check and adjust whether the pedal stroke in the specification.(Refer to section BR Gr./On-vehicle service/Pedal stroke of parking brake)
14.Install wheel and tire.
15.Push the parking brake pedal to the floor once and release pedal. This will automatically remove the slack from and correctly adjust the parking brake cables.
16.Test the vehiche on the road. The adjust will continue the brake adjustment during the road test of vehicle.
Inspection
1.Inspect the disassembled parts for wear, rust or damage.
2.Measure the thickness of brake shoe lining.
Standard : 0.17 in (4.5 mm)
Minimum : 0.04 in (1 mm)
3.If the shoe lining is less than minimum or shows signs of uneven wear, replace new one.
4.Measure the inside diameter of the brake drum.
Standard : 10 in (254 mm)
Maximum : 10.07 in (256 mm)
5.If the inside diameter of the brake drum is more than maximum or shows signs of uneven wear, replace new one.
6.Inspect the lining and drum for proper contact. If the contact condition is improper, repair it with a grinder or replace the brake shoe assembly.
Aug 14, 2013 | 2002 Kia Sedona
Replacing the rear drums after the shoes are in. Don't seem to want to go on.
Sounds like the shoes are adjusted to far out, adjust the shoes in (closed) until you can fit the drum there should be just a slight drag when you rotate the drum.
Mar 17, 2011 | 2002 Kia Rio
How to change rear barke shoes
Brake Drums & Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Release parking brake.
  3. Remove rear wheel assemblies. NOTE: If brake drum is stuck, install two 8 mm bolts into threaded holes and tighten evenly.
  4. Remove top return spring, front and rear shoe spring clips and hold-down pins.
  5. Remove anti-rattle spring and adjuster spring. NOTE: Note position of operating lever prior to removal.
  6. Remove bottom return spring.
  7. Remove clip and washer and detach parking brake cable from rear shoe.
  8. Remove brake shoes.
To Install:
  1. Lubricate all brake shoe contact points with appropriate grease.
  2. Place operating level into position on hub.
  3. Install rear brake shoe and connect parking brake cable to rear shoe with washer and clip.
  4. Install front brake shoe and install bottom return spring.
  5. Install hold-down pins and spring clips.
  6. Position operating lever and install top return spring.
  7. Install anti-rattle spring and adjuster spring.
  8. Install brake drum and screws.
  9. Adjust brakes and install rear wheel assemblies.
Jan 21, 2011 | 2003 Kia Spectra
How do i adjust e brake on 2006 kia rio
The Kia Rios (assuming yours is equipped with rear disc brakes) utilize a system that incorporates the parking brake into the rear calipers. What this means is there really isn't a way to adjust the brake itself, since it is part of your rear service brake. If you really wanted to you could adjust the cable at the parking brake lever. This would more than likely require removing your center console to get to it. The problem is if you over adjust, you will cause constant contact between the rear pads and the disc, causing premature padwear. You really shouldn't ever need to adjust the parking brake, but if your really wanted to, that would be how to do it.
Jan 14, 2010 | 2006 Kia Rio
Parking brake on my 01 kia rio(standard) no longer holds
parking brakes are adjusted at and with the rear brakes,..(drum brakes that is),.....as you adjust the rear brakes to have a slight drag as you spin tire, the parking brake is adjusted at the same time,...they work together with that one adjuster,....as you pull on the parking brake, it makes the brake shoes spread apart just as they do when you push the brake peddle,..by adjusting the rears you'll also find that the brake peddle feels better too.
Jan 06, 2010 | 2001 Kia Rio
How do you adjust the rear brakes on a 05 kia spectra5 ? It has disc brake front and rear.
Disc brakes are not adjustable. You may have a parking brake that is like a mini- brake shoe in the middle of the rear rotor. Those are adjustable, but tough to get at, and they rust badly. Look to see if your "cable" goes either to an arm that actuates the shoes, or if it goes to the caliper. If it goes to the caliper, you have no parking brake shoes.
Jul 28, 2009 | 2007 Kia Spectra5
I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
Drum, Rear Brake System Standard Rear Brake
Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
Heavy Duty Rear Brake
Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
The rear drum brakes:
  • Have internal shoes that expand against the brake drum (1126).
  • Are a single-anchor type.
  • Are actuated by one rear wheel cylinder (2262).
  • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
  • Adjust rear brake shoes and linings (2200) automatically.
  • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
Apr 04, 2009 | 1997 Ford F150 Regular Cab
Acer Aspire T650 (AST650UC3601) PC Desktop Logo
338 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
