Question about Video Game Consoles & Games
What is the unlocking code and serial for split second in manual activation
Unlock code
give me the unlock code for split velocity pc game
Aug 23, 2013 | Disney Split/Second - Windows
How to unlock radio from a2001 chey cavalier
see this technique and fix it. God bless you
Instructions
  1. With the Unlock Code
    • 1 Locate the anti-theft/unlock code. Most cars have a special anti-theft radio card that is included with the owners manual packet containing the unlock code and serial number. Some cars also have the code in the car manual or inside the glove compartment. You will need this code in order to unlock your car radio.
    • 2 Turn the car's ignition switch to the "on" position. This turns on your car's electrical system and powers up the radio. The word "CODE" will display on the screen. Note: depending on the manufacturer some radios will display either "ENTER" or "LOC" on the screen instead.
    • 3 Enter the anti-theft/unlock radio code. Press the "Tune" button on your stereo. It will change the screen from "CODE" to blank. Press the button to scroll through the available numbers. When you reach the correct number press the button once and hold it down for a few seconds. The number will appear on the display and you can now repeat the process to input the second number, third number etc., until all of the numbers are in. If you entered the code correctly the car stereo will unlock and instantly become functional. Depending on your car manufacturer, if you enter the code incorrectly you will not be able to re-enter it again from 1 to 24 hours.
    Without the Unlock Code
    • 4 Call your car manufacturer directly. Your car manufacturer's phone number is in your owner's manual. Ask to be connected to the support department. Tell them you need to reactivate you car stereo and you will be asked for proof of ownership. They will need your car's VIN number, the account number from your bill of sale and a form of personally identifiable information like your driver's license. You may need to fax this information. Once everything checks out the manufacturer will give you the code.
    • 5 Enter the code and unlock your stereo. Use the code you received from the manufacturer to unlock and and activate your car stereo.
    • 6 Go to a car dealership. Take your car to its manufacturer dealership to get the stereo unlocked. For example, if your car is a Honda go to a Honda dealership. Once you have proven that you are the owner of the car, the dealership will be able to retrieve the code from the manufacturer and activate the radio for you.
Oct 04, 2012 | 2001 Chevrolet Cavalier
I need The unlock code for ford transit 2003 my seriall number is M004102 thanks you part no. 1c1f-18c838-bc
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Ford service centre and get them to enter this code for you.
Aug 07, 2012 | Visteon Car Audio & Video
Cannot find split second unlock code
Try a warez site....We don't give out activation keys or codes.
Jun 07, 2012 | Video Game Consoles & Games
Split second unlock code and serial
i need a uulock cord & serial num of split second
May 15, 2012 | Disney Split/Second - Windows
How to change the keypad code on a 2001 mercury grand marquis
look for the permanent code on the plastic card in the owner manual packet. Or, pay dealer to extract code from computer.
Keyless Entry Keypad Code Programming NOTE: The system only allows one code to be programmed.
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds after activation will erase the stored customer code . The door locks will lock, then unlock, confirming the code is erased. The existing code will not need to be erased to program new a code.
  1. Within five seconds, enter the new five-digit keyless entry keypad code. The door locks will lock and unlock to confirm the new code is programmed.
Feb 08, 2010 | 2001 Mercury Grand Marquis
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
Video Game Consoles & Games Logo
77 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
