Question about Zoom X6 (5590) DSL Modem (55900003)
Xoom x6 adsl modem problem
I have a Xoom x6 wireless modem. I gave a passwod to the wireless network and i have three computers connected to the modem. Two wired one wireless. My connection frequently went. To fix it I need to power off and on the modem . What could be the porblem ?
  • sergioali Nov 20, 2007
    My X6 worked fine until it started to dissconnect(DSL light starts blinking, and internet light off) for no reason. Initially, it would do this when the computer it is set up on was switched off, but now it does this every 10 mins. I called the Zoom helpline and all they said was to download the Firmware update (which i did, and it worked fine for a couple hours), or contact the ADSL provider, which is not necesary because there appears to be no problem with reguards to that connecting to them. Is there some sort of setting i need to change, so that it would stay on, even when the computer it is set up on is off? (The way is was when i bought it 1 month ago)
    Problem Solver:
  • 8 Answers
Possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
Posted on Oct 19, 2007
Can i remove ethernet cable after installing router because when i do i lose connection
A router basically acts as a translator between networks to enable inter-connectivity. Your question was not descriptive enough. I think you are using a wireless router to route a wired network to a wireless one. If that is so, the router should be connected to both. For instance an ADSL or DSL Gateway router should be connected to the ISP through the wired cable and at the same time act as an access point (i.e. a getway, DHCP etc) to the local network. If this doesn't give you enough information try to clarify your question and i 'll try 2 help.
Nov 22, 2009 | Zoom X6 Adsl Modem/router Rohs...
Wireless WPA connection problem to Zoom ADSL X6
ya there is filter oing inbound also check port forwarding in router and check firewall to.
Default ip for access belkin router is http://192.168.15.1
May 05, 2009 | Zoom X6 (5590) DSL Modem (55900003)
I have a Zoom X6 ADSL modem that keeps dropping my internet signal. How can I correct this?
is it wireless connection or ethernet? Zoom routers have a firewall and when you have something connected that the firewall doesnt like (Xbox 360 or Gaming) it will drop the connection. goto zoom.com/x6 and it will give you instruction on how to by-pass the firewall using an different IP address.
Mar 22, 2009 | Zoom X6 Adsl Modem/router Rohs...
Zoom aDSL modem/wireless router seen but not connecting
Here are a couple of ideas to look at first, assuming you haven't tried them already:
1) Does moving the router help? Sometimes a new DECT phone or a microwave, or even a piece of equipment at a neighbour's house, can interfere with the signal.
2) Does changing the channel on your router help at all? If there are many other networks using the same channel, this might block your own signal.
3) If this does not make any difference, it might be worth checking your security settings.
Nov 14, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Zoom x6 model 5590 wireless router
Make sure the Connection Type is set to Static IP on the setup page of the router
Mar 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
ADSL X6
presuming that the router moved with you the telephone line socket could be too far away from the BT socket or is not correctly wired. if you have not moved the router then you need to buy a booster
Feb 18, 2008 | Zoom X6 Adsl Modem/router Rohs...
Zoom x6
The wireless is disabled either on your laptop or on modem. Here is quick guide of your modem that may help if it does not please let me know where is the problem and tell me what laptop do you have.
Jan 31, 2008 | Zoom X6 Adsl Modem/router Rohs...
Difficulty in first time support with zoomX6 5590
Hi Maybe i could help you. I have installed this modem before for an ISP provider. Please give me specific task you want to do and I will explain what to do.
Apr 30, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 (5590) DSL Modem (55900003) Logo
369 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Michael Galve
Michael Galve
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
