Question about GE Microwave Ovens
Need to replace ge microwave jvm1730dm1bb
What replaces and fits bracket easy install?
MicrowaveSvc
  • 9098 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
SOURCE: Replace OTR Microwave
Thanks for responding. It is a EWave KOT-152UW. I think EWave is part of Magic Chef. I think it is the door switch. When I opened the microwave, the circuit breaker tripped. I reset the circuit breaker, and it worked for several days, but the last time, the microwave went dead. The reason I want to use the same bracket is it has through the wall (horizontal) venting to the outside, and I am not keen on trying to cut more holes.
Posted on Nov 09, 2008
SOURCE: Need replacement microwave to fit existing trim kit
Finally built up the courage to call GE Appliance number and weave my way through the phone menu system. Pressed the right menu option (sales) to speak to someone about trim kits. Found out that the trim kit model number is JX1527MWW. Then called back to select a different menu option (other) and learned from someone else that since the trim kit model is more than 1-2 years old, there's a slim-to-none chance any new microwave models will work with it, and even if there was they couldn't easily cross-reference against a model that old to tell me which one (or something to that effect). So I hit a dead end. Only option for me at this point is to buy a new microwave with new trim kit.
(Personal note: I think the trim kit business is a racket, in bed with the microwave manufacturers. Why else would there be no standard dimensions for microwaves by now--like refrigerators have--and why is it a few pieces of sheet metal cost over $150? Pretty convenient that every microwave model needs its own trim kit model!)
Posted on Nov 22, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken Bottom Latch Pawl GE Advantium 120 Microwave
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
  • 13 Answers
SOURCE: I need install instruc. for a Whirlpool wallmount microwave.
sears should be able to get you the installation instructions and maint manual for this also, get on line go to sears.com and look up uour microwave part number like you did and look for the manuals
Posted on Dec 31, 2008
How to remove ge microwave model jvm1730dm1bb from under cabinet
The installation manual for your model is located here:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40538.pdf
BUT in many cases, a microwave can be repaired affordably.
Need a second opinion?
Contact me directly with your model number, FCC ID number, and detailed symptoms.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Dec 09, 2017 | GE Microwave Ovens
What model would be equal to a sharp microwave model R1490
Chances are only an identical model will fit the brackets. Any new unit will come with new brackets. Just swap the brackets out and install the new unit
Oct 16, 2016 | Sharp Microwave Ovens
Jvm230wl I want to replace my over the range GE JVM230WL model but I'm not sure the exact dimensions. It appears to be a snug fit in the bracket so the measurements need to be manufacture specific. Also,...
GE Customer Service is here. They may be able to tell you if there is a "drop-in" replacement available for your model.
Otherwise, you'll have to take down the old bracket then mount another model in the space.
Jan 15, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven - need to replace auto vent door
IF YOU KNOW NOTHING OF ELECTRICS ESPECIALY M/WAVES LEAVE WELL ALONE THET CAN BE ===LEATHAL===I MEAN LEATHAL.
Oct 04, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I broke the 13.5" removable
try the MARCONE website with your model#. be prepared to spend a small fortune for this tray.
Aug 06, 2011 | Microwave Ovens
I currently have a non-working over the range microwave, I have bought a replacement. How to I take one down and replace it with the new one?Are the brackets interchangeable?
What brand Microwave are you removing and what brand are you installing? If the are not the same brand they will mount differently. On an older GE you remove the two screws holding the unit in place. They are located on top of the unit on the front. Look in the cabinet above the microwave. After you disconnect the vent pipe the unit slides forward and out. On some other brands the unit will pivot down and then you lift it off a mounting bracket. To make the job as easy as possible and to make sure the vent pipe does not have to be moved, remove the old unit before buying a replacement. Look at how it mounts. Then buy the same brand and it should mount the exact same way, so you could use the old mount. But even then the manufacture may have changed the way it is mounted. I just replaced a GE with a Whirlpool and they mount completely differently. I even had to move the vent pipe 2" to the right. So stick with the same brand and hope they have not change the mount.
Dec 15, 2009 | Microwave Ovens
Removal of unit from wall bracket
You can download GE installation instructions here.
Then you can see how it went up to help you get it down.
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Installation of GE Microwave Oven
We have changed out a GE for another same brand, newer model. You will need two people to make the change-one of the two must be strong enough to support the unit after you remove the 3 bolts that hold it into the cabinet above. You will see these screws in the bottom shelf of the cabinet above your unit. A driver drill w/ the socket attachment to fit these "screws" would make it go faster. You'll need a step stool or a step ladder to get above the unit. There is a power cord that plugs into an outlet-make sure you have unplugged this before starting.While one is supporting the unit, the other is unscrewing the three bolts, When screws are out, the person on the ladder should come down and help w/ the unit removal. The unit is tipped forward to release it from the wall, as it is hooked into a bracket affixed to the wall. When you tip it forward, both of you should be prepared to lift it off the bracket. It helps to have the way cleared and a table or countertop ready on which to set it. BTW, My microwave installer did not use the flange provided to seal the vent around the cutout in the lower shelf of the upper cabinet. Removing ours, I can see why, there is no way to get the unit lined up w/ the flange and the duct and still tip it into the provided cut out. We bought metal sticky duct tape to seal it, and used the opportunity to reseal the above cut outs as well. I think some cabinets are constructed around the microwave installation, and if so, you could use the existing flange set up. When you are ready to put in the new one, do it in reverse, but schedule some clean up time in between, the grease finds a way of eluding all systems and you'll want to 409 it before putting in your new one. If this is too mu8ch for you, ask an installer or a neighbor to help-it doesn't require an electrician. You might want to ok into what GE is doing these days so your aren't dissappointed w/ the new unit after such a successful run with your first purchase.
Jul 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Can I reuse mounting plate for new microwave?
i always reccomend to my custs that they stay with the same brand for same mounting bracket, dontreally know a way to verify other hten removing hte old micr first and then before purchasing ask to open box to check
Mar 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
New Microwave
Well one would presume you could simply measure the bracket and the microwave, and ask a retailer for the dimensions of units with similar dimensions.
They may also have this bracket and be able to compare the sizes before purchasing your new one.
Not knowing the dimensions of either the bracket itself or the microwave, this would be the only solution i can think of.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
115 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
