Question about Boston Acoustics VR965 Speaker
VR965 midrange buzzing
Midrange speaker in BA VR965 has started to buzz during playback. Occurs only in the left speaker (tested by switching receiver inputs). Xover board looks clean and without visible damage.
2 Suggested Answers
injunearing
  • 81 Answers
SOURCE: How do I remove the
Use a scribe or something with a hook on the end that will fit into the holes on the grill. Make sure you use the hook as close to any one of the four corners and pull until the grill cover pulls out. it is just a black pliable adhesive that holds them in.
Posted on May 19, 2011
Testimonial: "exactly what I needed to know"
Hi....I need a wiring diagram for the stock amp in my grand am gt...its a 2003
Monsoon System Pinouts
Pin Wire Color Function
E1 LT GRN Right Front Speaker Output (+)
E2 TAN Left Front Speaker Output (+)
E3 GRY Left Front Speaker Output (-)
E4 LT BLU Right Rear Speaker Output (-)
E5 DK BLU Right Rear Speaker Output (+)
E6 BRN Left Rear Speaker Output (+)
E7 YEL Left Rear Speaker Output (-)
E8 BLK Ground
E9 BLK Ground
E10 DK GRN Antenna Relay Coil Supply Voltage
E11 ORN Battery Positive Voltage
E13 BLK Left Front Tweeter Speaker Output (+)
E14 YEL Left Front Tweeter Speaker Output (-)
E15 DK BLU Left Front Midrange Speaker Output (+)
E16 LT BLU Left Front Midrange Speaker Output (-)
F1 DK GRN Right Front Speaker Output (-)
F2 LT GRN Right Front Speaker Tweeter Output (+)
F3 PPL Right Front Speaker Tweeter Output (-)
F4 PPL Left Rear Tweeter Speaker Output (-)
F5 RED Left Rear Tweeter Speaker Output (+)
F6 DK GRN Right Front Midrange Speaker Output (-)
F7 ORN Right Front Midrange Speaker Output (+)
F8 PPL Gain Control Signal
F9 -- Not Used
F10 YEL Right Rear Tweeter Speaker Output (-)
F11 WHT Right Rear Tweeter Speaker Output (+)
F12 -- Not Used
F13 LT BLU/BLK Right Subwoofer Speaker Output (-)
F14 DK GRN Right Subwoofer Speaker Output (+)
F15 DK BLU/WHT Left Subwoofer Speaker Outlet (+)
F16 LT GRN/BLK Left Subwoofer Speaker Outlet (-)
or it is here 3rd one down
http://www.grandamgt.com/forum/forumdisplay.php?f=76
May 08, 2011 | Audio Players & Recorders
Just the tweeter is playing and not the mid
It's a midrange component speaker. Possibly your midrange speaker is blown. Check your wiring.
You hear the tweeters i am assuming because the vehicle has tweeter component speakers that are separate from the midrange and low components.
Apr 19, 2010 | VIFA P17WJ-00-08 Car Mid-Range Speaker
The speaker is starting to buzz during the low
It probably buzzes all the time, you just notice it when it is outputting little volume. Check the cables for loose connections or replace them with other cable as a test.
Mar 08, 2010 | Sony SA-WM40 Subwoofer
If i increase the sub woofer volume the voice distorts and gives a buzzing sound. it works fine on low volume
Your sub woofer is not mean for voice sound...check that you have connected the systen up properly and that you have put the sub woofer into its wn connection..if it is in the right connection the woofer could be blown.also try decrease the midrange hurts on the woofer
Jan 03, 2010 | Audio Players & Recorders
How do i take midrange speaker out of dash it rattles and dash is split
Hi
You will need to take the dash cover off. Just get a #20 torx and you can do it. The speaker is attached to the underside of the panel.Due to design choices like cheap paper cones and foam surrounds, after a few years of use, midranges don't sound great and almost invariably disintegrate. Then you get awful buzzing and crackling.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | Mitsubishi Eclipse Spyder Cars & Trucks
No sounds out of midrange and high speakers
The audio amplifier located in the trunk on the right side has failed.
May 11, 2009 | 2002 Mercedes-Benz C-Class
Vibration in midrange speaker - Infinity Kappa Series home speake
I have what sounds like the same problem with my Infinity's. Found a small crack in the foam surrounds of the speaker cone. Looking for a place to buy rebuild kits on the internet when I found this. Hope this helps.
Mar 18, 2009 | Audio Players & Recorders
I have a Pioneer Elite VSX-80TXV My front left channel is quiter and has significantly less midrange and bass than my other channels. The EQ's are on the factory settings but the channels are not equal. I...
The problem was actually at the speaker. The speaker I was using was a Kef speaker and it was missing a metal bar running across both negative terminals in order to power both the tweeter and woofer.
Nov 04, 2008 | Pioneer Audio Players & Recorders
My speakers sound flat with no highs at all
I am trying to work out if you have damaged the speakers and amp too.
Have you tried a pair of headphones on the amp? If they sound ok then your amp is fine.
Assuming it is, then speakers have what's called crossover units in side each of them. This splits the sound into three parts. Bass, midrange, treble. The bass is handled by the woofer's, the midrange by a middle sized speaker or or it's combined with a tweeter, which of course handles the treble.
Connecting a 1.5 volt battery across any of the individual speakers will cause it to pop if working. If the speaker then is not getting sound then the crossover unit is to blame.
When you look at the crossover unit, it will have coils and capacitors (non polarised) on it. The bigger ones deal with the bass and the smaller ones treble. If you find a fault say on the crossover of the speaker, for example no treble comes out of it. Then start by replacing the capacitors. Use the same value as on the capacitor and remember they fit any way round.
Apr 14, 2017 | Paradigm Audio Players & Recorders
Boston Acoustics VR965 Speaker Logo
23 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
