Question about Westinghouse Electric Westinghouse 28070 Outdoor Wireless Remote Control with Key Chain Transmitter 6Inch Cord Green
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
Need instructions to program Stanley Model DR-1212
Timer is not identified.
Following link has wide variety of timers and manuals, including Westinghouse/Stanley timers
Water Heater Timers Save Money
Dec 05, 2014 | Stanley Hardware & Accessories
How do I program remote control 28070T
What type of machine is this?
Dec 03, 2014 | Cars & Trucks
How do i program stanley radio transmitter model 28070T
U will have to get your manual or go online to Stanley and reprogram the remotes.
Nov 30, 2014 | Vehicle Parts & Accessories
How do I get a model 28070T radio transmitter?
Westinghouse 28070 Outdoor Wireless Remote Control Transmitter Is avalable at Amazon if this is not what you were talking about please be more specific..
Oct 28, 2014 | Radio Communications
Am programming Toyota Camry 2008 model key less remote with SBB key programmer Tool,But when ever,i get to the final stage to register remote to ECU after pressing lock and unlock at the same time on the...
If there is a communication problem, You run the risk of triggering an anti-theft function in the ECU resulting in disabling the ignition. Your best bet is to have the dealer program the fob
May 30, 2017 | Toyota Cars & Trucks
Westinghouse Electric Westinghouse 28070 Outdoor Wireless Remote Control with Key Chain Transmitter 6Inch Cord Green Logo
2,646 people viewed this question
Top Westinghouse Electric Home Security Experts
Lawrence Oravetz
Are you a Westinghouse Electric Home Security Expert? Answer questions, earn points and help others
