Question about Acer Aspire 5050-3242 Notebook
Sometimes no display on screen of acer 3680 when starts
Hi I have an Acer Aspire 3680 and since few months when i start my laptop there is no display on my monitor. i can hear the sound of fan it is running, all the light from cd rom and indicator blicks but the screen is very dark . i can feel there is some text running and laptop is starting but no display on screen (visible very thin- i tried alt+up arrow but do not work )then i again shutdown the laptop from start button directly and starts repeatedly . when i repeat this process many many times then sometimes it works sometimes not.
This problem happens frequently in 2 or 3 weeks so these days i don't fold the screen and let it as open. This helps me a few but problem is not totally solved yet. In the meantime i also format this laptop thinking that may be it helps me but i have not get any differences. when i have this problem and i directly shutdown the laptop i am feeling that it will hurt my PC more but i have no other alternative and i am very worried about this problem . so i am expecting your suggestion.
  • Acer Master
  • 32,281 Answers
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 18, 2009
Acer aspire 3680 notbooting black screen when power is on
if you can hear your fan noise when you start your laptop and cannot see anything on screen,that means your motherboard is faulty and you will have to replace your motherboard
Once you replace your motherboard,your acer aspire will be fine again
Thanks
Aug 02, 2010 | Acer Aspire 3680 Laptop
Baclight only stays on for a few seconds on my
You might want to give this a try. Start Menu - Choose Control Panel. Then choose Power Options. You should have several options depending on performance or saving power. Choose Change Plan Settings, and adjust the display brightness to suit your needs.
Hope this helps.
Sep 28, 2009 | Acer Aspire 3680 Laptop
Screen jumping on acer aspire 5920
First boot in safe mode and the display resolution will be minimal if the screen appears ok with big fonts then try and adjust the normal resolution but not high resolution like 640x480 with 256 colors, if it works then you acer laptop screeen is fine but the exactly display drivers to be reloaded else there is a problem with your laptop screen which needs to be replaced
Mar 18, 2009 | Acer Aspire 5920 AS5920 Notebook
Screen of my acer 3680 turns off and the laptope power off
try system recovery.or try recovering windows through a Rescue disk.
Feb 28, 2009 | Acer Aspire 3680 Laptop
White screen problem while starting Acer Notebook 4710
i think this is ur lcd problem ,u need to replace lcd
Jan 20, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3680 won't start
It`s dead ,DOA sorry dude.......
Dec 30, 2008 | Acer Aspire 3680 Laptop
Laptop powers up but does not display desktop
How to enable / disable windows active desktop. Open Display Properties. Click the Web tab in the Display Properties window.
DirectX Help Get the computer into Safe Mode. In Safe mode, click Start / Settings / Control Panel and double-click on the display icon.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3680 Laptop
Screen Flickering on Acer 3680-2682
Ok we must remember when we setup any device on our PC, one of the many non PnP devices is and LCD Monitor, your PC should always be shutdown before installing a new Monitor. If you did not do this you could have damaged the I/O port on your PC. Not a definite, but possible! When you plug up a monitor or any serial cable while the PC is still on, it is of a low voltage which can casue some issues for you! Sounds like this one is yours!
Nov 21, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 5050-3242 Notebook Logo
869 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
