Question about Roper REX3614KW Electric Dryer
Dryer sounds like a blender
I have a roper dryer. when i turn it on it kinda sounds like a blender. what causes this
3 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: roper elec dryer
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance.
Clicking on the underlined links will take you directly to that page.
Very rarely, a voltage issue could cause this symptom, but you should rule out the other possibilities first, unless you have a volt-ohm meter, then a quick check of the voltage MAY rule out these other issues.
This could be a motor or drive system issue. To test for a motor problem, you will need to remove the drum belt. See exploded view diagram link below, for disassembly.
http://www.repairclinic.com/0100_16.asp
If the motor fails to start, replace the motor, See link below.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=2584&PPStack=1
If the motor starts, then you will have to look for:
1. Blower obstruction
2. Rear drum rollers.
3. Idler pulley
4. Drum belt, See link below
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=587636&PPStack=1
5. Front tub glide bearing and seal assembly. See link below.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=2702&PPStack=1
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 11, 2008
TheMobilian
  • 8220 Answers
SOURCE: roper dryer
One of them drum wheels is bad.To get to it: Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Get the drum out and inspect the wheels.
Posted on Dec 31, 2008
Roper dryer makes a buzz sound then shuts off sounds like its trying to turn but does not what could this be
Might be something in the blower housing bogging down the motor. My home movie shows how to replace a belt and check for objects heat etc.
ROPER DRYER
Jul 31, 2012 | Roper Dryers
My Roper gas dryer will not start. It does make a humm/click sound when the button is pushed. The sound comes from behind the setting knob. Is there a fuse?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 15, 2011 | Dryers
I have a roper dryer and it buzzes when turned on. it wont turn
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Mar 28, 2011 | Roper Dryers
Roper dryer will not run. Model # REX5634jq0
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 30, 2011 | Roper REX4634KQ Electric Dryer
I have a Roper dryer Model: RED444OVQ1 that won't turn on .
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 20, 2011 | Roper Dryers
After replacing my belt and drum rollers my roper dryer has a clicking noise as it rotates
Could be a lot of things causing it, blower wheel, motor, idler pulley, rollers. Dryers have several moving parts that could cause a clicking sound. The blower fan could be coming into contact with something. There is a motor, tensioner and a belt that turn the main drum, the tensioner for the belt could be loose thus causing the clicking noise as well.
Oct 16, 2010 | Roper REX3614KW Electric Dryer
Roper,model# rex5634kq1 Just quit working. wont turn on or anything
heatman101
Sep 08, 2010 | Roper Dryers
The drum on my Roper won't turn, help!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 09, 2010 | Roper Dryers
Roper electric dryer wii not start
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 05, 2009 | Roper RES7646KQ Electric Dryer
Roper REX3614KW Electric Dryer Logo
51 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
