Question about Cellet Professional Retractable Car Charger for Nokia E500 Phone with OneTouch button system (Lifetime Warranty)
Phone start-up failed contact the retailer ... nokia E50
I have full phone memory in my nokia e50... but i did not delete data from it...once i have switched off my cell phone.. when i try to On my phone ...it does not start and shows message like this '' phone start-up failed contact the retailer'' please help me...i have very important data in it and i dont want to lose my text messages and contact in my phone... thanks
My phone shows memory full close some applications,but i want to keep many applications open,and e50 is a multitask phone,how to solve this problem.
This message is usually shown on Symbian smartphones when the phone memory is too low or when there is a malware program in the phone memory.The only practical solution is to clean up the phone memory.The Nokia E50 has 70 MB of internal memory (phone memory).You should have enough free phone memory to run many applications.To clean up your phone memory please follow the instructions below.
1.Back up your contacts to the memory card or SIM directory.
2.Enter *#7370# on your phone.
3.Press YES when prompted to restore the settings to factory defaults.
4.Phone is restarted.
Note this this will clean up your phone memory only and all the data in the memory card will be safe.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jul 03, 2011 | Nokia E50
I forgot my lock code password and i want to format it now so i can use the phone my phone is E50 nokia please help me
dear hotness_erro
try the code *#7370# for the complete reset it will delete all the data on the phone.
by the way default code for the phone is 12345.
Gagan
Mar 14, 2011 | Nokia E50
I want to reset my nokia E50....
---HARD RESET (total reset/formatting)
This option restores the original operating system from the ROM. Formats the C:partition and deletes all data including the memory card. Key Code *#7370#(click this combination of keys on the keyboard in the mobile).
Reset Code : 12345
Hope this help and if helpful RATE please.
Feb 11, 2011 | Nokia E50
I was using black berry then i switched to nokia e50 and i remove the mmc from black berry and when i inserted it to nokia e50 memory card is currupted how to solve this problem
You may need to format the memory card with your Nokia device.
However, all data in the memory card is permanently deleted if you format the memory card.
It is recommended to back up device memory regularly to the memory card. The information can be restored to your device
later.
To back up information from device memory to a memory card, select Menu > Tools > Memory card > Options > Backup
phone mem.
To restore information from the memory card to the device memory, select Menu > Tools > Memory card >
Options > Restore from card.
Do not remove a memory card when the card is being accessed. Removing the card in the middle of an operation may damage
the memory card as well as the device, and data stored on the card may be corrupted.
If you cannot use a memory card in your device, you may have the wrong type of memory card, the card may not be formatted
for your device, or the card has a corrupted file system.
Tip: You can install and remove a memory card without removing the battery or powering off the device.
Dec 21, 2010 | Nokia E50
Sir how to format the internal memory of nokia e50
Internal memory can only be formated step by step....for this you have delete all your sms first then..then you have to delete all your data on the galary except the data on card.....
Oct 18, 2010 | Nokia E50
Nokia E50 cellphone will not boot up. Stuck on Nokia Logo. Is there any way to retrieve my contacts from the phone memory? Many thanks.
Seems like your phone is now corrupt and you cannot retrieve any data stored in it , the only solution is to hard reset it , as you cannot start the phone , you have to go for key based hard reset by pressing the Green button , '#' and '3' key and start the phone .
All data will be lost but you will have your phone back , I recommend using OVI Sync to backup your contacts or on your PC via Nokia Suite backup
Sep 09, 2009 | Nokia E50 Cellular Phone
Formet of Nokia E50
Type from the right to the left #0737#* then type the code :12345 (this code is the original code)
Mar 22, 2009 | Nokia E50
I wanna know how to format my nokia e50
Try This :
Note :- Formatting data drives run a risk of loosing unbacked up data.
Mar 18, 2009 | Nokia E50
Formating nokia e50 while keeping my data safe!!!!
can any one tell me how to format phone memory......... i know there is some code
Nov 19, 2008 | Nokia E50
Cellet Professional Retractable Car Charger for Nokia E500 Phone with OneTouch button system (Lifetime Warranty) Logo
22 people viewed this question
Top Cellet Cell Phones Experts
William Alequin
Are you a Cellet Cell Phone Expert? Answer questions, earn points and help others
