Question about GE GTDP490EDWS 7.0 cu. ft. duradrum electric dryer with he sensordry
My GE Dryer GTDP490EDWS will not start at all, the power supply to the dryer checks ok
docjohn174
  • 943 Answers
SOURCE: ge dryer
Hi Thanks for the question .Open the door,screws under top. remove screws. lift up top. 2 screws on the inside of front , remove. pull front away front bearings on the front support. . thanks the appliance doc. Please rate my answer thanks
Posted on Oct 06, 2008
frcs68
  • 1605 Answers
SOURCE: How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
Posted on Apr 23, 2009
  • 864 Answers
SOURCE: Reset GE Profile Harmony Dryer
Try here: http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
Posted on Sep 15, 2009
mikes112
  • 56 Answers
SOURCE: GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Posted on Mar 23, 2010
SOURCE: my GE Profile Harmony dryer wont dry clothes
I finally had a GE authorized tech come to our house, because we've had the same problem on and off for about 2 yrs. Our's is 5 1/2 yrs old, and the problem was the blower motor, which is hard to get to, and the nut holding the fan in place is also put on going the "opposite" direction. (So lefty loosey, righty tighty doesn't work for this one) The Tech told me in all his years he has never replaced a heater in any of these, and it has 2. The usual problem is the blower motor has gone bad. It's working great now, and it was $470 to fix, but still cheaper than a new one....
Posted on May 16, 2010
Wiring diagram
Look online. There are plenty of sources that has schematics and wiring diagrams.
You can also check inside, behind the steel panel on the back of the dryer.
Apr 08, 2016 | GE GTDP490EDWS Electric Dryers
What to check when Dryer heats, but not moving air?
Does the dryer sometimes stop heating? Do you always use the lint trap when using the dryer?
May 02, 2014 | General Electric GTDP490EDWS Front Load...
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Takes several cycles to dry
Ge Dryer 4 years old model DBVH512EF0WW no heat power is good to dryer heater ok thermostats ok PROCESS OF ELIMINATION LEADS ME TO a power board above drum, diagram says it has some relays on the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Sep 10, 2011 | GE DCVH515EFWW Electric Dryer
I have a GE dryer mod# DCVH680EJOMS, and it runs but no heat. I have checked the power supply, thermostats, and the coil. they all seem ok. Any advice? Thanks, Jason
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 19, 2010 | GE DCVH515EF Electric Dryer
My GE DPSB620ECWW does not light up the pannel or
Check circuit breaker at the house electric panel, if good, check for voltage (220/240)volts at the receptacle that the dryer power cord plugs into, if good, check for voltage(220/240)volts at the dryer terminal block where the dryer power cord connects to the dryer, if good, check voltages at the dryer power transformer, should be 220/240 volts for motor,and 110/115 volts control power for dryer controls, you should find the failure within these inspections/testing.
Good Luck !
Mar 15, 2010 | GE Profile DPSB620ECWW Electric Dryer
Apr 23, 2009 | GE DVLR223 Dryers
GE GTDP490EDWS 7.0 cu. ft. duradrum electric dryer with he sensordry Logo
122 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
