Question about Frigidaire FPHD2491KF Dishwasher
Start button works intermittently - Frigidaire FPHD2491KF Dishwasher
What causes start/pause button to work sporadically?
It sounds like the switch is getting bad, contacts in the switch no doubt have burned spots and it is hard to get a connection through burned spots. So I would say replacing the switch is in order.
Jun 21, 2014 | Maytag MDE5500AYW Electric Dryer
Power button works intermittently
Yeagh, mine started doing that after I replaced my duff dell power supply with a half priced double the watts 'generic' one ..
I stopped worrying about it years ago .. and the PC is still working
Apr 03, 2014 | Dell Studio One 19 PC Desktop
I havy my ASUS K40IN,,my problem is about powering it up,,i'm having trouble of opening up ,i always press the power button very hard,but it takes me time before opening,sometimes when lucky its e
It is possible you have a intermittent power on/off button that is not working properly, remove main battery to see if that will help, if not! unplug power supply from laptop and remove main battery, next press and hold power for 2 minutes to get rid of any residual voltage, now put everything back together and power up.
May 06, 2012 | ASUS K40IN Notebook
Radio works intermittent - 0603 code / CHECK on the display
Some can go into "security mode" if power was lost. Popping sound doesnt sound good to me, VW often has seperate amp under driver dash. Id check all power sources but I bet the error code is mech failure.
May 11, 2009 | Car Audio & Video
My 98 golf won t start intermittently. I replaced
If you run a push button directly from the battery to the solenoid, the engine will crank when you push the button.
If the no start condition is because of the solenoid, this will not fix the issue.
If the no start condition is related to circuitry of the ignition system and/or fuel system, this may fix the issue, but may not, as well.
Apr 08, 2009 | 1998 Volkswagen Golf
Cd player in van not working properly
Is it always 20 minutes or is it random. If it intermittently switches off, i would say that the power button has a problem. Maybe there is dirt, or moisture simply tha the switch has no 'spring action' anymore that it touches the contacts.
May 13, 2007 | JVC KD-S580 CD Player
Remote problem
It sounds like an intermittant Infared sensor problem or there is an intermittant solder connection between the sensor and the controler chip. Good Luck
Apr 08, 2007 | Kenwood VR-407 Receiver
Frigidaire FPHD2491KF Dishwasher Logo
65 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
