Question about Lightwedge Camping, Backpacking & Hiking
Light won't stay on - Lightwedge Camping, Backpacking & Hiking
Pilot light wont light
Rita, Check the attached links,instruction and guides to trouble shoot pilot light, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gas Heater Pilot Light Troubleshooting
What to Do if Gas Furnace Pilot Light Won Stay Lit DoItYourself com
Furnace Won Ignite Why and What to Do
Aug 03, 2016 | Heating & Cooling
Clicks but won t turn over
Most likely a bad or low battery or bad connection or bad solenoid or starter or combination of any of them. Those lights will mostly stay on till the engine cranks before going off.
Jan 28, 2014 | Hyundai Sonata Cars & Trucks
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
I have a 1996 acura rl and my problem is my remote entry won't work and my cluster light won't shut off and the check engine light came on all at once don't have a clue as to why
remote entry wont work because either remote battery is dead or remote broken.cluster light will stay on if head light stay on could have faulty headlight relay or headlight control unit faulty let dealership check it out.
Sep 09, 2012 | Cars & Trucks
Battery light stays on car loses power, battery won't stay charged
check charging system like altenator or make sure battery cables are clean and tight. go to advance or autozone they will check it for free.
Jul 09, 2012 | 2008 Dodge Avenger
Delonghi Superser won't light there is gas getting
Clean pilot first see if it lights if not you could change thermocouple
Apr 03, 2012 | DeLonghi Heating & Cooling
Have an Oldsmobile 1997 Achieva security light stays on and won't everyhing but still won't start , would like to know would the Pro VATS Full Bypass work on it.
If the security light is on, then you have a failed antitheft system. This light is only for this. If you bypass the system, your car will work perfectly again.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Feb 04, 2012 | Cars & Trucks
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
Camping, Backpacking & Hiking Logo
29 people viewed this question
Top Lightwedge Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Lightwedge Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
