Car Audio & Video Logo
A
Anonymous Posted on Dec 28, 2013
Hi I have a EONON G2104 car audio system and i`m trying to find out wher do I need to connect the orange wire which is the backup reverse gear wire ?
2 Related Answers
Anonymous
  • 7 Answers
  • Posted on Mar 05, 2010
SOURCE: Eonon E1025 when you connect the orange wire
sorry, "the orange wire (reverse gear) is just driven the chamber on the display of the radio without doing the reverse"
what do you mean by this?
Anonymous
  • 10 Answers
  • Posted on Nov 30, 2010
SOURCE: Installed reverse camera to Eonon
i had the same problem with my talon today, all you need to do is get another wire , connect one end to the 12v(red)backup tail light wire and connect the other end to ur dvd player and put it one the wire that is to be connected to the 12v for the revarse camera the wire should be orange but urs might be a different color.
Reverse lights stay on in drive 2004 buick rendezvous cxl
Backup Lamps
The TURN SIG fuse in the console fuse block supplies battery positive voltage to park neutral position switch. When the gear selector lever is in the REVERSE position, power is supplied to both of the backup lamps. The backup lamps are grounded at G401 and G402.
Do you know what DTC'S - diagnostic trouble codes are ?
DTC B2552
The body control module (BCM) controls the backup lamp relay. The BCM grounds the backup lamp relay control circuit energizing the backup lamp relay. The BCM connects directly to the center console fuse block with no external wiring between them.
DTC B2553
The body control module (BCM) controls the backup lamp relay. The BCM grounds the backup lamps relay control circuit energizing the backup lamp relay. The BCM connects directly to the center console fuse block with no external wiring between them.
Backup Lamps Always On
  1. Turn ON the ignition.
  2. Shift the gear selector lever to the REVERSE position and then to the PARK position.
Do the backup lamps turn on in REVERSE and turn off in PARK?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
Remove the backup lamps relay.
Do the backup lamps turn OFF?
Go to Step 5
Go to Step 4
Repair a short in the backup lamps relay switched battery positive voltage supply circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you complete the repair?
Check the back-up lamps relay #45 in the center console fuse/relay box .
Fuse Block - Center Console
Inside of console, behind the right console access panel
Check
Pyle plcm7300bt what does the green wire reverse car wire connect to + or ground
The green wire connects to the backup lights control. When the gear shift is in "Reverse" this acts as the switch on the "Monitor" and turns the system on so you can see what's behind you to safely "Backup" Hope this helps you.
2answers
Hi i have a eonon e1015 when trying to play a dvd it saying no disc and the same with music cd.sd card works fine radio works what could be the problem I think its laser problem thanks.
I just installed a new eonon 1015 and i cant paly any CD or DVD, it seas that there is no diskt....i think i have installet correctly, but there is another orange cable wich i didnt know where to connect...can you hel please ?
1helpful
2answers
Installed reverse camera to Eonon E1025 unit. Power for the camera was taken from the reverse lights (positive and negative). Video wire from camera was taken back to the E1025 unit. I expected the orange...
2answers
Hi ive got an eonon e1012 double din dvd player unit for my car (vw golf mk4) I can watch dvds but there is no sound atall when i put a dvd in or a cd, It did have sound when i 1st had it wen i put in a cd...
hi, i bought eonon E1012 on Eonon official, i also changed the wire so as to watch car DVD, but everything turn out to be fine.
I think maybe you have connect the wrong wire and have bum out the built in amp.
1helpful
Eonon 1025e screen mechanism broken. Need to replace two of the gears but cant find spares anywhere
Hi I have the same problem.E1025 unit has broken gears to make unit come out so just removed broken gears and manually pull out.Screen would fold up and down still until today .Now the other plastic gears have broken.I have tried to contact eonon to buy spares but dont wont to know about it.Now looking at old remote cars,video recorders etc to find something that will fit.No luck yet will let you know if i do. Eonon ****
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
