Question about Garden
My craftsman blower/vac model # 358.794741 will not start because the gas from the fuel tank will not **** up through the fuel lines I just replaced.
Gas from the fuel tank is not being sucked up through the fuel lines.
  • 2418 Answers
SOURCE: on weedeater blower and vac gas line is broke from
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
Posted on Jul 12, 2009
  • 885 Answers
SOURCE: I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
Posted on Nov 02, 2010
  • 85 Answers
SOURCE: what do you need to take apart to get to the top
The left side but be careful there are alot of screws and the trigger mechanism they can be a pain if you dont feel comfortable then go to your local small engine shop.
Posted on Feb 20, 2011
  • 458 Answers
SOURCE: The assy-fuel pick-up on my Craftsman 25cc 200MPH Blower/Vac Model No. 358.797550 has come of and loose in gas tank. How do I repair it?
Mine did the same thing,also sucked trash into the carb.You will have to get the weighted pickup/filter out of the tank(long needle nose pliers or a parts grabber claw).The hose is long enough to pull it out of the fill cap.Cut the end off as straight as possible,and remove the broken line from the filter.Push the line back on,and drop the filter back in the tank.
Posted on Jun 14, 2012
hunter19_46m
  • 7482 Answers
SOURCE: Need a diagram for replacement of fuel line on a blower/vac model # 358.798980
Hi jfkunz
I think this is what you are looking for.
Please rate me
Bud
Posted on Oct 13, 2012
How to change fuel line on craftsman blower
Before you start take a picture of where the old lines are connected to the carb and the primer bulb for future reference.
To replace the line pull the spark plug wire from the plug. Remove the old line from the tank and remove the fuel filter from the line. Take new larger line and cut it on a 45 degree angle/or trim as necessary so you can grip it from inside the tank and pull it into the tank. Perform the same operation on the smaller line as well. Be sure to leave enough line for the fuel filter to reach the bottom of the tank. Install the fuel filter. The other small line is a vent line and only needs to come inside the tank not go to the bottom in the fuel.
Good luck.
Jun 07, 2014 | Craftsman 4 Cycle Blower/Vac
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Hi jfkunz
Please rate me
Bud
Oct 12, 2012 | Craftsman Garden
On Craftsman Blower serial 07101 N200438=25cc TWC Model 358-794964
I NEED TO REPLACE THE GAS LINE ON MY CRAFTSMAN MODEL 358-794964
Jun 26, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
While using Craftsman blower it was running low on gas. I turned it off and when i opened the gas cap, it appeared to be highly pressurized. I filled the tank and when I pushed the primer bulb to restart...
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor, fuel lines, and fuel filter.
Jul 23, 2011 | Craftsman 225 Mph Electric Blower Vac
On weedeater blower and vac gas line is broke from carb into tank does it just connect to fuel filter in tank model 1925
Jul 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Replaced carb I bought from Sears and still no gas to the plug.
Replace your fuel lines and fule filter (usually inside the tank). I have found a number of times that just heat and time will couse some problems with the inside of the fuel lines. Hope it helps!
Jun 24, 2009 | Craftsman 4 Cycle Blower/Vac
Model 358 craftsman blower, where is the fuel filter
Follow the fuel line from the tank to the carb. If it has one, its in that tubing line. There will prolly be a particle filter screen inside the tank to keep crud from getting to the carb. Other than that - there's really not much to the fuel system on these.
Jun 22, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
