Question about Campbell Hausfeld MIG / Flux Core Wire Feed Welder
Wire feeder broken
Wire does not come out.
Mechpro 100amp mig welder
It won't arc without wire in it. If the motor runs then there may not be enough tension on the feeder wheel to push the wire thru. If you had a bad kink in the inner liner it will not feed. The trigger switch in the handle applies arc voltage to the copper nozzle. It may be bad or have a broken wire.
Dec 15, 2013 | Welding Tools
A new welding machines lincoln 500s with wire feeder linc feed 45 co2 gas shielding ... when i begin the welding process continueous just for 10 seconds and then the wire feeder stop and then after 50
the obvious, yet sometimes overlooked problem is to check if the wire feeder rollers.do you have the proper tension set?(did you do the wire test when you shot the wire to see if it bends or stops)
Apr 11, 2013 | Lincoln Electric Welding Tools
Cigweld wire wasp mig welder wire feeder worn need replacement also operation manual and plastic feeder cable holder is broken need new one located in Mandurah W.A.
http://www.thermadyne.com/IM_Uploads/DocLib_1498_43-59.PDF
http://www.thermadyne.com/IM_Uploads/DocLib_1673_CIGWEL56.PDF
http://www.thermadyne.com/IM_Uploads/DocLib_4168_0-4949.pdf
http://www.thermadyne.com/IM_Uploads/DocLib_4143_0-5072.pdf
If your gun end is a Tweco, those are pretty much standard and readily available from welding supply houses. If the retainer for holding the liner is broken you would get that through Thermadyne.
Jan 08, 2012 | Welding Tools
Can the lincoln 305 d 1727-3 mig weld
If it has a setting for constant volatge, that is for wire feeders, flux cored or mig. Constant current is for stick welding. Some wire feeders have a switch to use them with a constant current machine, but that doesnt work very well, and , in my opinion, is hard on the computer in the feeder.
It looks like the ones we use in the field with a ln-25 wire feeder and flux cored wire. for mig you will also need a bottle of sheilding gas.
Jan 28, 2011 | Lincoln Electric Ranger 305D K1727-2...
Wire broken off inside of liner at both ends
Hi Ray,
You can remove the liner from the gun and replace it - probably cost you about $15. Liner comes out from rear of the gun. The rear of the gun (that plugs into the feeder) is removable. Once this is out, you can remove the liner from the rear of the pin. Remove front end consumables, install new liner, cut it to proper lenght at front of the gun, and replace gun back into the feeder, reinstall the front end parts and run wire through and beyond tip, cut it leaving about 1/2". Now you can weld again.
Apr 19, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
I have a Copystar CS-2020 and it is showing error code A-O 410 on the screen what does this mean
Document Processor communication problem. This is due to a faulty ground connection.
Open the doc feeder lid, check the left hinge. There are two versions of grounding tab: a small one and a bigger and better one. Both attached by a screw.
Twist the small metallic tab that grounds the hinge with doc feeder metal frame in order to create better contact. Worst scenario, the doc feeder cable has a broken ground wire at the holding strap (inside the back rear cover of the feeder, which is hold in place by plastic clasps. If you are handy you can solder the wire ..
Feb 17, 2009 | Copystar CS-2020 Copier
Im tryint to conect my wire feeder
ask weld tech at a welding supply store and ask if your components are compatible (since most wire feeders are 24 volts).
Dec 19, 2008 | Welding Tools
Miller axcess 40v wire feeder
give me a day or so and i will have the solution for you
Sep 11, 2008 | Welding Tools
Hp officejet 7310 document feeder cover
no my friend.. just opened back cover the wire connected in pcb just remove then reconnect. thats all..
Aug 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet 7310
better u disconect ur document feeder wire connection. and than try that.
Campbell Hausfeld MIG / Flux Core Wire Feed Welder Logo
55 people viewed this question
Top Campbell Hausfeld Welding Tools Experts
rjivaro
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Campbell Hausfeld Welding Tool Expert? Answer questions, earn points and help others
