Question about RCA Televison & Video
Screen shakes and has stripes
Rca model rlded4016a the manual says to adjust the impulse phase to decrease stripes. RGB in. However, I have no idea what this is and can't find anything on the tv that remotely resembles this. help
SOURCE: hyundai lcd tv
Mine does this too. Sorry if i tell you the wrong button, because i can't test it right now because I'm having the problem where my remote doesn't work. But i would either push the MTS button or the P. Mode don't remember which it was, but it would change the audio from stereo to mono and i think you want mono to fix it.
Posted on Sep 12, 2008
Rick60639
  • 29 Answers
SOURCE: can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Posted on Dec 01, 2008
SOURCE: Need a remote code for the tv 37" Sabre LCD Tv Model # lct371bka. RCA Universal remote Model # RCR660
as soon as u bought the universal remote it came with a paper that say a bunch of codes find ur tv model go to set up look were u can put in the code and follow the code exact
Posted on May 24, 2009
  • 6 Answers
SOURCE: "I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Posted on Jun 03, 2009
  • 5 Answers
SOURCE: activate RCA Universel Remote with Ascent
this may work for all universal remotes, im using the philips SRU3003/27 universal remote. it doesnt contain a code for my t.v., however after searching the internet n all that. i was able to program my tv. and heres how 1: Manually turn on ur tv 2:hold setup untill red indicator stays on and release button 3: press and quickly release what you wanna program (i.e tv,vcr,ect.) 4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again. 5: press and release MUTE to install the code. i hope this helps for all those who have had to deal with these nice but annoying tv.s
Posted on Jul 17, 2009
Screen splits into 3 separate images not convergence
Make sure you re-adjust convergence in HD and non HD modes if your TV has HD
Mar 30, 2013 | RCA HD52W59 HDTV Projection Television
Its glittery white because i briten the color but when darken it gets green
you must re-adjust in the RGB (Red-Green-Blue) setting. depending on the brand of your TV, because there are set manually from the TV (you must open the cover of the rear of the TV). and there is a set directly from the remote only, with the open "factory settings", then you can re-adjust RGB color, especially green, not too dominant with the other colors (RED-BLUE). how to set is that you need to neutralize the color, (color TV sets to zero level) so that the image becomes black and white. if the green is too dominant, then Decrease the level of Green Bias or Green Cut off/ G-drive.
Aug 05, 2010 | Televison & Video
Window screen is smaller then the monitor. it is on the
For presice adjustments of VGA input run the Auto Ajustment Software on the CD
Additional image quality improvement use the clock and clock pahase controls of the monitor to fine tune the image
Clock increase or decrease the value to minimize any vertical bars or stripes visible on the screen backgroung
Clock phase increase or decrease the value to minimize video distrotion or video jitter
  • allow the monitor to heat up before adjustments
  • use the adjustment pattern application provided ont he CD
  • select OSD menu to select image control and change clock or clock phase
  • Incase of any error restore factory settings select the OSD menu and select factory reset and select yes
Feb 25, 2010 | HP 2159M Monitor
I have a Ingersoll Rand Type-30, Mod#2475
when you remove the pressure switch cover,there is a screw on the top screw clockwise means increasing air pressure and anticlockwise means decreasing the drlivery air pressure
Sep 11, 2009 | Ingersoll Rand - Rand Type - 30...
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Print is clear and fuzzy
I'm sure you have fixed this by now... But solution is...
Check the hammer phasing. Adjust hammer phasing if
necessary.
6. On the control panel, press the = + > keys to unlock the ENTER key.
“ENTER SWITCH UNLOCKED” briefly displays. (If “LOCKED” displays,
simply press = and > again. This is the default key combination. The lock/
unlock key combination can be programmed by the user. If = + > does
not unlock ENTER, get the combination from the user.)
7. Press the ; key. “OFFLINE / DIAGNOSTICS” displays.
8. Press >. “DIAGNOSTICS / Printer Tests” displays.
9. Press >. “Printer Tests / Shift Recycle” displays.
10. Press ; until “Printer Tests / Phase Printer” displays.
11. Press ENTER. The display shows “Printer Tests / Phase Printer” and the
test begins. The current phasing value is printed on the left of the printed
pattern of all H’s. As the pattern prints, compare the H’s to the figure
below. If the phasing needs adjustment, go to step 12. If the phasing is
OK, go to step 15.
12. Press >: The current phase index displays. Press > again: An asterisk (*)
appears next to the phase value.
13. Press < to increase or ; to decrease the phasing index value, then press
ENTER to activate the value as it prints. Continue to increase or decrease
the phasing index until the pattern of H’s is acceptable.
14. Press = twice: “Printer Tests / Phase Printer” displays.
15. Press ENTER to stop the test.
16. Press CLEAR. “OFFLINE / CONFIG. CONTROL” displays.
17. Press = + > (or the key combination set by the user). “ENTER SWITCH
LineMatrix
Sinca Printers, Parts, & Repair
www.sinca.biz
Jun 11, 2008 | Printronix Line Matrix P5215 Printer
I need the color adjusted
1)Remove rear cover..clean RGB lens with soft cloth....
replace cover...........
2)Remove front speaker grill & access panel.....
locate RGB screen control block.....slighty adjust RGB
for best color mix.......check B/W tracking by reducing
customer color control to minimum....does pix look gray ?
touch up RGB screen again.....then increase color to middle
of range.....how is that ?......................................T.
Feb 21, 2008 | Televison & Video
Adjust Picture on Rca Projection TV
check the horizontal frequency and the electrolytic filters used in it. damm sure there must be filter that make it look like a concave. also check it by decreasing the width from the service mannual of processor. there is a service switch for every processor. that is his internal control unit. may be it is from the processor adjustment. you can set it by increasing or decreasing the frequency or display width-height clock pulse from the processor. to know about that perticular switch you must concern to the company....
Feb 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCD 52W20 with no green...
Re-check hook up on focus/screen adjust assembly.Adjust RGB screen controls.All green/ no control can be bad green CRT==check w/CRT checker.CRT OK/==diagnosis required.Green video drive circuit??
Jul 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
GE washer - Excessive shaking in between phases
how old is the washer? depending on the age and the model the problem could be different things
Jun 23, 2007 | GE WBSE3120B Top Load Washer
Televison & Video Logo
42 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
