Question about JVC AV-32950 TV
Model AV-32950 will not turn on. The power light is flashing and the relay RY921 is oscillating. I have replaced C926 1000uf/35v & no change. Any suggestions. Circuit daigrams????
  • TVQueen Apr 15, 2008
    Tv keeps clicking off and on but no picture. Smells like something is burning. Took the back off but don't have any technical experience.
  • 93 Answers
Did you check his horizontal transistor?what is the voltage of the b+ in flyback. but common causes of that model is the defective horizontal transistor.
Posted on Oct 18, 2007
Screen is blank and timer light is flashing
try to read the manual of that television
Dec 22, 2010 | JVC AV-32950 TV
Mitsubishi WS-65511 has flashing timer light but will not turn on.
I used to have a WS55909 and had this problem. The light is supposed to blink for one minute while the DM (digital module) boots up after a power loss. If the light continues to blink indefinitely, there is a problem with that board. The DM power supplies are known to have faulty capacitors on these models and will need to be replaced. If I remember correctly, there are (7) 1000uf 25v capacitors and they should be desoldered from the board and replaced with 35v ones. Note that my TV model already had 35v caps but changing them solved the problem: electrolytic capacitors have a much shorter life than other components.
The DM is on the left side and is where ANT-DTV and the IR repeaters plug in. The power supply is the board above the main DM board inside the DM case.
If this sounds too technical for you, get a new TV because a repair guy will charge you more than the TV is worth. In other words you could get a (30-46") LCD TV for the same price.
Oct 21, 2010 | Mitsubishi WS-65511 65" Rear Projection...
I have a JVC AV-32950 and have lines running across the top 3 - 4 inches of the picture. The picture also goes black on occassion and I have to hit the top of the TV to get the picture to come back. While...
It may be a dry solder point somewhere near the vertical IC. First take look at the solder points and if you found cracks pls resolder it. if the lines continous you have to replace Caps near the vertical or circuit.thank you
Nov 23, 2009 | JVC AV-32950 TV
My magnavox 37MF321D/37 will not turn on. It
I had the same problem with the blinking green light. These are the parts one the power supply I replace to repair it. note: If the power supply is repaired you will get a solid green light and the backlight will light up almost immediately.
Aug 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Tv shuts itself off randomly
hi
you have defective power oscillation in power section
this needs to diagnose for a qualified technician
Thanks!
Feb 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv won't come on
check the relay drive transistor
you need a qualified tv repair personal to check tv
Jan 15, 2009 | JVC AV-32D305 32" TV
Won't turn on, On/timer light is flashing and clicking
If you are interested and you have skill and touch you can surly be able to do it. but if you don't have any knowledge i prefer you to send it to repair center may be it doesn't cost much.
Sep 08, 2008 | JVC AV-32950 TV
Jvc will not power up
Not, just install soldering stations on the terminal capacitor ( bottom) and pull up slow, clean solder and put it back new one. See position ( -- And + )
C926 and C928 1000uf 35v Common problems.
Some time D905 shorted
Replaced C911 470 uf 35V
Ready!!!
May 10, 2008 | Televison & Video
Need manual control board (power,volume, channel and menu push buttons)
Manual push buttons part number should be CM35776-B01-SA.
Give me a few hours--I'll get the remote part number....T
Oct 30, 2007 | JVC AV-32950 TV
Unit power up have sound but no picture.
Check the damper diode and the protection resistor in the High Voltage circuit. Good Luck.
Jun 18, 2007 | Philips 55PP9363 55" Rear Projection...
JVC AV-32950 TV Logo
130 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
